Old 05-07-2011, 04:20 PM
Brianstick Brianstick is offline
Black diamond abrasive
Has anyone tried the Black Diamond abrasive that Tractor Supply sells? I was wondering, is it like the glass beads, or more like aluminum oxide? Thanks.
Old 05-07-2011, 06:20 PM
papaharley03's Avatar
papaharley03 papaharley03 is offline
Re: Black diamond abrasive
If it's like the Black Beauty I got at Northern Tool, it's actually coal slag. A much safer, low silica alternative to sand. I used it on my welder restoration project and was pleased with the results. It won't be as smooth as glass bead.
Papa
Lincoln Idealarc 250 (circa 1962)
Lincoln Weldpak 155 w/Mig Kit
Lincoln Squarewave TIG 175
Old 05-07-2011, 10:09 PM
Oldiron2 Oldiron2 is offline
I believe this is the MSDS for that product:
http://www.ati-blackdiamond.com/new/...fety4B5222.pdf
I haven't used any so can't give you an opinion about it.
Are you planning to use it in a blast chamber, or outside? Just curious.
I didn't look to see what grit sizes are available. We don't have any Tractor Supply stores out here, but I assume Black Diamond sells through lots of other outlets.
Old 05-07-2011, 10:37 PM
tigmusky's Avatar
tigmusky tigmusky is offline
very course, works good for heavy rust. may have to up your tip/nozzle size.
What are you blasting?
Daye
Pound to fit, paint to match
Old 05-07-2011, 10:46 PM
I'm using glass beads now in my blast cabinet but it just isn't course enough. I'm looking to get something to cut faster, I blast mostly rusty steel.
Old 05-08-2011, 01:08 AM
Fegenbush Fegenbush is offline
Papa
Close, Papalion. It is fly ash slag. They burn the coal, and sift the ash. Black Beauty is a specific size of that ash. The big stuff they grind to be the right size or use it to make asphalt shingles, the small stuff is landfilled. I used to work near a plant that sifted it. I was never quite sure how they stayed in business...
Old 05-09-2011, 04:02 PM
ironmangq ironmangq is offline
A lot of that fly ash is ending up used in concrete these days to replace portland cement, I think some farmers are also using it as a cheap fertilizer, I know a lot of power plants are getting paid for the stuff now when just a few years ago they were paying to dispose of it
HTML code is On
