Old 05-14-2011, 09:19 PM
Jack772 Jack772 is offline
Spray Transfer
I have a Millermatic 252 that I use for Short Circuit welding. I would like to try Spray
Transfer. I would like to only use one shielding gas. My local welding dealer is Praxair.
What would you guys recommend?
Thanks,
Jack
Old 05-14-2011, 09:27 PM
technomaster's Avatar
technomaster technomaster is offline
Re: Spray Transfer
why spray transfer ? why wouldn't you just weld it normal with normal settings ?
Old 05-14-2011, 09:29 PM
irish fixit irish fixit is online now
Re: Spray Transfer
I get into spray mode pretty well with C25 and 0.035" wire on my Millermatic 252. No it's not perfect but it does work. The main time I notice the difference is at the start of the weld. It doesn't always start out smoothly with C25.
And for the second poster actually the top two setting on 0.035" in the chart are in the spray transfer mode range. Thus it is in the normal settings.
Millermatic 252
XMT 304
Dynasty 200DX
Hypertherm PowerMax 1250
Miller The Legend AEAD200LE
Suitcase 12RC
Suitcase 8VS
Optima Pulser
XR feeder and XR Edge gun
and more at
http://members.dslextreme.com/users/waynecook/index.htm
Old 05-14-2011, 09:55 PM
DSW DSW is online now
Moderator
Re: Spray Transfer
You're probably in globular mode not true spray with 75/25. Usually you need to be in the 15% or less CO2 range to get true spray IIRC. We usually use 92/8 argon/CO2 for short arc/ spray mix with the XMT's.
To the OP, might find this thread useful as well.
http://weldingweb.com/showthread.php?t=54543
Ronald Reagan
Old 05-14-2011, 11:04 PM
MrLeadMan MrLeadMan is offline
Re: Spray Transfer
What are you referring to as "normal"? Spray is a widely used mig transfer process.
To the OP we use 98/2 AR OX or 90/10 AR CO2 for spray with .045 wire. 98/2 requires less amps.
Ranger 250 GXT
Smith Gas Axe
Old 05-15-2011, 03:35 AM
Rizz01's Avatar
Rizz01 Rizz01 is offline
Re: Spray Transfer
90/10 is good for an all around mix to be spray capable.
Personally, I mainly use 75/25 cause achieving spray mode is not important to me.
Measure twice, cut once.
Millermatic 211
Millermatic 251
Miller Dynasty 200DX
ESAB O/A Set-up
Old 05-15-2011, 08:53 AM
Re: Spray Transfer
I know you're supposed to have less CO2 for true spray. But it is possible to get spray with C25. It's just not as stable. Like I said it doesn't start out as smoothly. In other words the first few seconds are globular and if you run into some contamination or get your gun angle wrong it'll jump into globular mode. The big thing about the CO2 is that it take more voltage to push into spray mode so turning up the voltage a little helps with this.
I promise it works. Try it sometime.
Millermatic 252
XMT 304
Dynasty 200DX
Suitcase 12RC
Suitcase 8VS
Optima Pulser
and more at
Old 05-15-2011, 12:12 PM
Re: Spray Transfer
Irish,
The point being made is that you recommended a gas mix that WILL NOT produce a proper spray transfer. The whole point of this thread (OP's question) was to get recommendations for his "setup".
To quote from Miller (and I really do think they know what their machines will do) is, "There is some acceptance of a 75%Argon/25%CO2 mixture for short circuiting and globular transfer."
Bottom line is if the OP wants to employ spray transfer, he needs to use the proper gas mix, and that's NOT C25.
I mix my own gases and I can tell right away (using the Thermco mixer) when I haven't properly purged my lines when shifting from c25 for short arc to C8 for spray.
If the OP insists on trying to "get by" with one gas mix, a combination of 90%Argon/10%CO2 (C10) is probably his best bet.
Actually, with the MM252, which in my estimation, is at the lower end of the "spray capable" machines, a mix of 98%Argon/2%O2 will yield a better spray bead.
As was mentioned in another post, the MM252 will produce a satisfactory spray transfer, however the standard M25 gun will not stand up to a steady diet of spray. I use a Bernard Q300 on my MM251 and a Q400 on the XMT.
Syncro 250 DX
Dynasty 200 DX
MM 251 w/30A SG
HH187
Dialarc 250 AC/DC
Hypertherm PM 1250
Smith, Harris, Victor O/A
Smith and Thermco Gas Mixers
Old 05-15-2011, 12:27 PM
Re: Spray Transfer
I agree that it's not perfect. But around here getting anything other than C25 would be a special order and probably take a month (actually it's sometimes hard to get C25). I was just saying that the MM252 does better than any of the other welders I've tried it on. I'm not setup to run my MM252 through my mixer since 99% of the time I don't use it for heavy stuff. But sometimes I'll grab it for the quick heavy repair that's not going to take a lot of weld. I've just got a Bernard 200 on my MM252 so it wouldn't take it for long. My XMT has a Bernard 300 on it and I've gotten it pretty warm more than once. It's what I use if I'm going to do a lot of spray since it's got the duty cycle to handle the big jobs.
Millermatic 252
XMT 304
Dynasty 200DX
Suitcase 12RC
Suitcase 8VS
Optima Pulser
and more at
Old 05-15-2011, 08:21 PM
Re: Spray Transfer
Has anyone tried Praxair's Stargon CS Gas Blend?
Old 05-15-2011, 09:00 PM
Re: Spray Transfer
Dang Jack,
Buy a bottle and test it yourself. It's not like you're marrying the bottle.
After your last post, I went back and read your previous posts. Here's a couple of observations:
a. You bought more welder than you needed if "the thickest I ever weld is 3/16"".
b. The MM 252 is a fine welder, but it won't do your job for you. YOU still need to do your part.
c. Worrying about "spray transfer" and what gas to use is fruitless at this point. It's too hot a process for the material you're dealing with and you'll find it useless (without pulse) to weld anything out of position.
I'd recommend you go to millerwelds.com and click on the resources tab. That will take you to an offer for their "Student Pack". It's $25 including shipping. Includes an excellent GMAW Handbook, a great TIG Handbook, a GMAW-P Handbook, along with a bunch of other useful goodies.
You, from your posts, seem to rely heavily on others telling you "how to" and "what wire/amps/etc" should I use. Spend a little more "hood time" and figure out a few things for yourself.
Syncro 250 DX
Dynasty 200 DX
MM 251 w/30A SG
HH187
Dialarc 250 AC/DC
Hypertherm PM 1250
Old 05-15-2011, 09:35 PM
Felonyass Monk's Avatar
Felonyass Monk Felonyass Monk is offline
Re: Spray Transfer
Praxairs " mig mix gold " gives excellent spray transfer and works great for short circuit. C 25 gives a globular transfer that some may confuse for the much smoother and almost spatter free spray transfer.
Felon
Caution lurker lives here
" hmmm That is serious,pass the ganja and pick up a 24 of MGD"
Old 05-15-2011, 10:20 PM
lotechman lotechman is offline
Re: Spray Transfer
I have a millermatic 250 and run C20. I can just barely get into spray with .035. I really need more argon if I was to get serious about it.
Old 05-16-2011, 08:55 AM
vpd66 vpd66 is offline
Re: Spray Transfer
I've had the same experience with my Millermatic 250. 80/20 just barely gets into spray transfer.
Old 05-16-2011, 11:41 AM
Alphonse Alphonse is offline
Re: Spray Transfer
I worked in a heavy plate shop years back, they had a production set up for spray transfer mig...used Airco Ultra-mix 80/20. and over 275 amps, 045 wire.
Spray transfer mig is a VERY HOT mode of mig welding for heavy plate say 1/2 " and over. Most mig machines will not enter the spray mode until overy about 250 amps. It is smooth as silk to run, compared to "snap, crackle and pop" short curcuit mig in my opinion. I admit the newer mig units are very adjustable to smooth out SCT mig.
Century AC/DC 250 Amp & Midstates 300 Amp Industrial AC stick welders, Century Flux core 80 amp. wire feed welder Harris Oxy-Acet. cutting & welding outfit:
SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
Old 05-16-2011, 07:44 PM
Re: Spray Transfer
Ran some spray arc at work today. Joining 10 gauge to 5/16 plate in a T joint. I have no idea what settings were because our stuff is old and has no read out or numbers on the dial for that matter. My point being, spray can be just fine for thin stuff. 10 gauge is just shy of 1/8th.
I have a copy of Modern Welding that claims spray with .045 wire can start as low as 200 amps with 98/2 or 95/5 gas.
Our boss likes spray arc so we use it as much as possible.
Ranger 250 GXT
Smith Gas Axe
Old 05-16-2011, 11:10 PM
Jweld Jweld is offline
Re: Spray Transfer
I use spray transfer 75% of the time on 1/8 and thicker steel with my miller 250x. I use .045 solid wire and goldgas steelmix3. Steelmix three also works well for globular transfer. The Two settings I use most are 24 / 200, and 26 / 325ish. Never have any problems just make sure your welding in a flat position, cause the puddle is very fluid. Uphill will fill your shoe, not the weld.
Old 05-17-2011, 08:39 AM
Baila La Pinza Baila La Pinza is offline
Re: Spray Transfer
Why are some of you guys using spray transfer on 1/8 material? Sounds like a recipe for distorsion, unless maybe you've got it in pulse mode, but even then, would it not be better just to set the machine up correctly in dip and still get smooth beads with minimal spatter?
