Old 05-22-2011, 08:44 AM
JohnL JohnL is offline
The rotor is toast??
Code 9656
Model WP 225 G7
Serial #A1181012
Onan 16 hp (XSI?) w/filter
Auction item, represented to work good. The motor seems to be perfect. No weld or 110 output so I took the cover off.
I am guessing that there are more problems.
I have not determined the proper rotor, possibly $800 and up.
Any help (or sympathy) appreciated.
John
Old 05-22-2011, 09:54 AM
Lanse Lanse is offline
Re: The rotor is toast??
Id take it back to the auctioneer, and explain it to them.
They represented something that worked, when it was obviously a smoothly running boat anchor.
"Overkill is an often under-rated achievement" -Will Hayden
HTP Mig 2400
Hypertherm Powermax 45
Lincoln Precision Tig 225
Longevity StickWeld 250
Hobart Stickmate AC/DC
Hobart Handler 187
a.k.a ChuckE2009 on Youtube
Old 05-22-2011, 10:05 AM
tenpins tenpins is offline
Agree with Lanse. The engine may have run well, but there is a whole other part. Ask them for _documentation_ that they tested the welder, or even put a tool into a 110 outlet. Or had an electrician even take a look at the welder. Anything to prove they gave the welder some thought. Be nice but firm. Casually mention a BBB complaint, or a review of your experience online. Good luck.
Weldanpower 225 G7
Ironworkers Local #24
Old 05-22-2011, 10:41 AM
MadMax31 MadMax31 is offline
That breaks my heart, my rotor looks nothing like that... Slip rings look toast as well... at least not brass colored like mine...
edit..
I dont see brushes in the holders, did you ohm the rotor? Slip ring to Slip ring should be like 4ohms I THINK. Duanne knows far better than me.
Theres also a flashing diode with a fuse in-line, if its blown, you wont get anything but an idleing engine...
Lincoln Weldanpower 225 AC/DC-Briggs
Lincoln 225/125 Tombstone
Lincoln Weld-Pac 100 HD
Jackson NexGen
A Pile-O-Lee tools
Sumner Ultra Clamps- where have these been all my life!
DWM120
More pipe threading tools than I can list
Old 05-22-2011, 11:04 AM
duaneb55's Avatar
duaneb55 duaneb55 is offline
My first question would be what was paid for it?
Yes, it was represented as working and obviously can't and if you just want your money back then I would talk to the auction company as others have already suggested. Especially if you have no need for or desire to have a good running 16hp Onan worth a several hundred that could be used to replace a dead one on a like machine if you found one.
If you wanted to keep it, you may be able to negotiate a reduced price with the auction company but I think that would be a long shot. Keep in mind the crank tapper will only fit Lincoln units and not Millers that used a different tappered crank output.
For a re-wind on the rotor, looks like Eurton Electric http://eurtonelectric.com/ (catalog pg. 57) will run between $345-450.00 depending on actual rotor dimentions plus shipping to/from California but I would check the stator windings (exciter windings in particular), reactor and output rectifier out first before making the investment.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 05-22-2011, 11:24 AM
Stick-man Stick-man is offline
I know a guy who bought a dozer at an auction. When he started it and when he went to move it, it would not steer correctly. He pitched a bitch to the auctioneer and they refunded his money.
So if it was represented as a working unit, not just a running unit, I would go and try. Any reputable auctioneer should make it right.
"Stick-man is wise" - Farmall
"Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550
"StickyFingers-man"
Commander 500D, LN25
Shopmaster 300, Super S-32P
Hypertherm Pmax 600
Smith & Oxweld O/P
Old 05-22-2011, 12:23 PM
soutthpaw's Avatar
soutthpaw soutthpaw is online now
I have bought and sold at several auctions. The key is is they said it runs or its is in good working order. you already said it runs so they were representing it correctly. auction companies rarely test equipment. sometimes you get stuck with a POS. If they said it was working correctly then its probably what the seller told the auction company. in that case be quick about contacting them before they send payment to the seller.
The key is what did u pay for it? I sold a hot water pressure washer at auction and made it clear itthat it needed a new pump. autioneer said nothing about it when it sold ut only sold for like $65 so no biggie. was also documented in the email i sent the auction co listing what I wanted to sell.
If you do buy at auction you will occationally get duped. its just the nature of the game. I have lost money on some stuff broke even on others and made money on some. if you strip the copper or motors out of it an recycle it you can get some money out of it and probably sell a good running Onan engine easy. electric motors are 60 cents a lb and copper is over $2 a lb...
Ya just missed out too. I sold a good weldenpower 225 that I bought for the choke at auction a couple weeks ago to fix my ranger 8, the generator and slip rings were in good condition, had a missing/blown engine
Airco 330A/BP. Lincoln SP250 W/ spoolgun, GoWeld x2
TA Predator, ESAB 300AVS Feeder, Powcon 300SM
ESAB 875 plasma. . Bernard Cooler. Evo 355. OA
Old 05-22-2011, 12:28 PM
I paid $850.
Oh, but it was such a clean unit and started / ran so good.
Auction fever.
It was a farm auction, I will first try the owners.
Beauty is only tin deep.
John
Old 05-22-2011, 10:00 PM
soutthpaw's Avatar
u may end up just putting it back in another auction to get some of your money back on it. where are you located
Old 05-23-2011, 12:23 AM
tanglediver's Avatar
tanglediver tanglediver is offline
John
That got me chuckling.
Too bad about the rotor though.
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 05-23-2011, 01:09 AM
DougAustinTX's Avatar
DougAustinTX DougAustinTX is offline
I've seen a welder like that with burnt windings and blackened slip rings before when the owner started the unit up and forgot that the work and electrode clamps were both clipped to the rail of his trailer and let it run for a while as a direct short. That one was a Miller.
Miller Syncrowave 350
Millermatic 252/ 30A spoolgun
Miller Bobcat 225g w/ 3545 spoolgun
Lincoln PowerArc4000
Lincoln 175 Mig
Lincoln 135 Mig
Everlast 250EX Tig
Century ac/dc 230 amp stick
Victor O/A
Hypertherm 1000 plasma
Old 05-23-2011, 08:54 AM
soutthpaw asked "where are you located"
Dillon MT
Old 05-25-2011, 11:54 PM
The owners have offered 2 options. Return the welder & all of the money back or about 1/2 back and I keep the welder. Honorably outfit!
I will probably return the welder out and start over.
John
Old 05-26-2011, 09:04 AM
soutthpaw's Avatar
John
very good deal, you got lucky with that one...
HTML code is On
