Old 05-31-2011, 09:52 PM
morgaj1's Avatar
morgaj1 morgaj1 is offline
Spray Arc Transfer
After seeing some pictures Dan posted of some spray arc transfer he did, I am fascinated. I have done a lot of searching here and on the web and still don't fully understand the process. Will someone explain this to me? It appears that this process is only possible with 210 amp and more MIG welders. Is this correct? Is a special wire used? Is it accomplished with 75/25 gas or something else? Any other info would be great.
Old 06-01-2011, 12:40 AM
srp61 srp61 is online now
Re: Spray Arc Transfer
lets see,
spray arc is generally limited to larger machines because it requires high voltage 25v+ and current around 180 amps.
you also need a high argon content gas normally with at least 85% argon.
the gas we use at work is BOC argosheild light which is 93% argon 5%CO2 and 2% oxygen
here is a vid showing spray transfer
and short circut
it is also normally used on steels 6mm(1/4") and above and is only suitable for flat position welding due to puddle fluidity, unless you have a machine which can pulse spray
Old 06-01-2011, 01:06 AM
soutthpaw's Avatar
soutthpaw soutthpaw is online now
see the thread about airgas steel mix, that is a gas that would work for spray arc. 90% or higher argon content... generally limited to a 250 amp and up size mig welders. My Ltec has the settings listed for both short circuit and spray arc and give appropriate gas recommendations right on the inside cover of the machine....
Airco 330A/BP. Lincoln SP250 W/ spoolgun, GoWeld x2
TA Predator, ESAB 300AVS Feeder, Powcon 300SM
ESAB 875 plasma. . Bernard Cooler. Evo 355. OA
Old 06-01-2011, 10:39 PM
morgaj1's Avatar
Is there any advantage, other than appearance, to spray transfer over short circuit?
Old 06-01-2011, 10:50 PM
Rick V's Avatar
Rick V Rick V is offline
Great educational comparison video's srp61 !
Rick V
3 CTC 70 amp Inverters in Parallel => 210 amps Stick!
1 Linde 250 AC/DC
1 Lincoln MIG PAK 15
1 Oxy-Acet
Old 06-01-2011, 11:03 PM
welderShane's Avatar
welderShane welderShane is offline
Better penetration with spray arc over short circut, faster travel speeds too.
Ya gotta spend money to make money!
Old 06-01-2011, 11:21 PM
BCRD BCRD is offline
With spray transfer there is less chance for a good looking weld with poor fusion. CWB does not allow for short arc for structural welding. - spray or pulse spray only.
Jason
XMT 350
Suitcase 8RC / Optima
Spoolmatic 30A
Thermco Ar / C02 mixer
Assorted O/A gear
Old 06-02-2011, 12:39 PM
addendum9 addendum9 is offline
A newer type of arc called the EWM-forceArc process is used with gas-shielded metal-arc welding in the upper power range (320 A Welding current vs. 285 A) using inert gases or high-argon content mixed gases. in the upper power range, which was previously reserved for the spray arc or long arc. Based on the welding trials carried out at TWI by an EWM welder, comparing to conventional spray transfer it was possible to draw the following conclusions.
* Butt welds made using the EWM-forceArc welding process with narrow preparation angles of 30º and 40º met the requirements of EN ISO 15614-1:2004.
* Due to the reduced joint volume, welding times for butt welds were reduced by up to 50% compared to conventional spray transfer with a preparation angle of 60º.
* Fillet welds made with the EWM-forceArc produced a mitred fillet with no undercut which also met the requirements of EN ISO 15614-1:2004
* The fillet weld made with EWM-forceArc showed a greater penetration than for spray arc.
Old 06-02-2011, 05:08 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
Short arc procedures are not AWS pre-qualified. So you can't go to the book and get a welding recipe for short arc.
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Old 06-02-2011, 07:31 PM
bmyers bmyers is offline
Shield gas composition, amperage, and wire size dictate whether or not you can spray transfer. Lower % of Argon typically means higher required aperage. Once you get below a certain point, I believe 80 or 85% Argon, it is not possible. Here is a link to some good info on the differences of short circuit, globular, and spray transfer.
http://www.esabna.com/EUWeb/MIG_handbook/592mig1_6.htm
Old 06-02-2011, 07:48 PM
morgaj1,
Don't know where you're researching, but a simple search should provide a lot of details about spray arc vs short arc.
I'd also highly recommend that you go to millerwelds.com and click on their Resources tab. That will take you to an offer for their Student Pack. It's $25 including shipping. Includes an excellent GMAW Handbook, a GMAW-P Handbook, a GTAW Handbook, as well as a bunch of other useful goodies. Best $25 you'll ever spend on welding material.
Spray arc welding is a high disposition, high energy weld, generally limited to the flat/horizontal position (without pulse) due to the very fluid puddle. Requires higher voltage/WFS than generally associated with short arc welding. Gas mix generally requires more than 85% Argon. Effective (duty cycle) spray arc welding is generally limited to machines of over 250A output.
Syncro 250 DX
Dynasty 200 DX
MM 251 w/30A SG
HH187
Dialarc 250 AC/DC
Hypertherm PM 1250
Smith, Harris, Victor O/A
Smith and Thermco Gas Mixers
Old 06-02-2011, 08:43 PM
morgaj1's Avatar
Lots of good info. Thanks guys!
Old 06-28-2011, 04:56 PM
EWI has designed, built, and tested a narrow-groove tandem gas metal arc welding torch that allows a high-deposition rate process to be used in a narrow groove. Benefits are increased deposition rates, decreased joint volume, increased tolerance to joint variation, and improved sidewall fusion compared to competing welding processes. "We are using tandem gas metal arc welding in combination with a narrow groove for an increase in deposition rate. Oscillation of the lead torch significantly improves sidewall fusion and tolerance to joint variation. We are doing a few things differently such as water-cooling the contact tips. We've had great success with the torch and are pursuing commercialization of the technology."
Watch the video. http://www.ewi.org/narrowgroovetorch
