Old 07-02-2006, 07:42 PM
scott brunsdon scott brunsdon is offline
Does welding affect smell/taste?
I noticed last night after spending the afternoon doing some welding and grinding that I couldn't really taste my dinner very well. Back to normal now. Anybody else have this happen? Maybe it was my imagination. Pity, because it was a great meal I made - strong flavours, too.
Scott
Old 07-02-2006, 07:56 PM
smithboy smithboy is offline
Moderator
Re: Does welding affect smell/taste?
For me...absolutely, it does. After a long period of welding, everything smells different. It's not like you lose you sense of smell, but like it's altered somehow. It's funny, I guess I never thought about it until you mentioned it.
Smithboy...
MicroZone MicroZone is online now
I am always really hungry after working and welding, so I just inhale my food. As long as it's not burnt or extremely hot, I think my food tastes the same.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 07-02-2006, 08:42 PM
zapster's Avatar
zapster zapster is offline
Moderator
not to me..
i have the worlds most sensitive nose
i can smell anything way before anyone else does..
and i absolutly HATE it
...zap!
No Comment
Old 07-02-2006, 10:07 PM
lotechman lotechman is offline
Apparently some of us have more smell receptors than others. Some are designated super tasters. I am at the other end of the scale. I don't tase much so along with that is the advantage of not losing anything I never had.
Old 07-03-2006, 12:23 AM
MAC702's Avatar
MAC702 MAC702 is offline
Scott, what were you working with? I've heard that a mild case of metal fume fever might have those symptoms. I'm not sure because I've never had it; I always stayed upwind and/or wore a respirator when working with questionable material (like galvanized.)
Old 07-03-2006, 01:47 AM
It was galvanised steel, but I ground off the gal from the weld site. And I was working inside because it was a cold day - normally I'm outside.
Old 07-03-2006, 02:12 AM
SSBN727's Avatar
SSBN727 SSBN727 is offline
Hey Scott!
I believe MAC702's "hunch" is correct with regards to your exposure to some poisonus fumes - no matter how slight, mainly because of the inadequate ventilation from being inside
I hope ya feel better soon because, I know how that can be so disorienting when exposed to the fumes as it happened to me when I first started out.
Respectfully,
SSBN727
"Run Silent... Run Deep!!!
Old 07-04-2006, 02:16 AM
Stick rod Stick rod is offline
Scott,
I agree with Mac and SSBN.Long time ago had the same thing happen to me with the galv.steel.Depending on the humidity level where I work sometimes I notice a slight change in smell/taste but for me it`s very seldom.
Old 07-04-2006, 07:30 PM
I'll have to grind more of the gal off next time.
Currently I'm coughing, sneezing and wheezing, but I put that down to germs brought home from school by a 3 year old and a 5 year old.
Old 07-04-2006, 11:54 PM
littlefuzz's Avatar
Here's a good link I found that goes into detail about galvanized steel.
http://www.sperkoengineering.com/htm...Galvanized.pdf
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-05-2006, 01:53 AM
So the symptons of metal fume fever are:
'...fever, chills, thirst, headache and nausea.'
I sure ticked all those boxes. Maybe I did poison myself on the weekend after all!
I almost feel like I've earnt my 'WeldingWeb Tradesman' tag!
Old 07-05-2006, 09:36 AM
Moderator
Hmmm. Now I have to say that even when I weld un-coated steel with mig or tig over a few hours, my sense of smell is affected. In fact, I think the effect is strongest when I use inert gas (double hmmm). I had wondered if there was something wrong with my nose, because even after I took a good long shower, everything still had "that smell," sorta like ozone, but everywhere and on everything. However, over time (hours maybe) my nose returned to normal. It's not a foul odor. Maybe I am alone in this or maybe there is something I am not thinking of. I know I don't have a super strong nose...I grew up on a cattle farm and near chicken houses and never thought anything of the smell.
Scott,
It does sound like you inhaled a bit of zinc based on your symptoms mentioned above...be careful with that.
Dang...now I feel like a hypochondriac...someone mentions their nose problem and now I got it and they don't......scott, this is probably a record for long-distance disease transmission. I hope bird flew doesn't infect my hard drive. Cough...cough...sniff...sniff
Smithboy...
Old 07-05-2006, 07:16 PM
I knew if kept reading enough posts one day one of you guys would use the word 'dang' - thanks Smithboy.
Now I have a picture of you in my head and it's not dissimilar to Ned Flanders.
Scott
Old 07-07-2006, 06:19 AM
Rockski Rockski is offline
well next time your working with galvanised, have about a litre of milk before and wear your respirator best way to avoid the zinc chills
