Old 07-08-2006, 04:43 PM
WHughes's Avatar
WHughes WHughes is offline
New Toys
We just received these this week at my job. Anyone have experience with either of these machines? I don't have dies for the bender yet, but we have been toying with the roller a bit and it seems to trip the circuit breaker in the control panel every once in a while. Not under heavy load, just aluminum. But it doesn't happen all the time. Our power supply in the building isn't the greatest, maybe thats it?
Bill
Old 07-08-2006, 08:46 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: New Toys
i'll take one of each
thanks
...zap!
No Comment
Old 07-08-2006, 10:48 PM
littlefuzz's Avatar
Re: New Toys
It's nice having that stuff at work, you don't have to pay for it (unless your the owner) and can use it anytime especially if ya have a key to the shop.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-09-2006, 12:33 AM
welder.man's Avatar
welder.man welder.man is offline
Re: New Toys
That makes two of us.
Simon
http://members.optusnet.com.au/~abba/index.html
Old 07-10-2006, 08:27 AM
TubularFab TubularFab is offline
Re: New Toys
Well, you couldn't have gotten a better brand tube bender than RMD! Are they going to get you a good assortment of dies? That's where the big bucks come in - expect to pay close to a grand a set for anything above 1.75" od x 6" CLR. RMD makes really nice benders - but maybe I'm biased since I know the guy that started the company and designs the machines!
Old 07-10-2006, 02:22 PM
mribeiro mribeiro is offline
Re: New Toys
I used one of those rollers for bimini bows on boats - draw a center line and use vice grips on the pipe to keep it straight - ours used to give you a wonderful twist if you didn't keep the work straight manually.
MM 175 w/ spoolgun
Old 07-10-2006, 08:16 PM
WHughes's Avatar
Re: New Toys
Yeah I have been battling a twist. Luckily its aluminum. Also for boats. Small world.
Bill
Old 07-11-2006, 07:31 AM
Re: New Toys
Bill - We used annodized alluminum - smaller softtops would get 3/4" - bigger ones 1" - both would twist. Keeping it straight with vicegrips gets you 99% there, you may need one or two tweaks at the hip bender. Now a days most owners want the molded fiberglass tops - no bimini bows needed there....I worked for a place called PipeWelders, the NJ plant has since turned over and is now called PipeTowers.
MM 175 w/ spoolgun
Old 07-11-2006, 05:22 PM
Rollman's Avatar
Rollman Rollman is offline
Re: New Toys
How long have you been working at Pipe Welders ? I knew a guy that worked for them about 10 -15 years ago . Are they still at South Jersey Marina
Old 07-12-2006, 08:29 AM
Re: New Toys
When I worked there we were in SJ Marina. I was there from 84-92. When I wasn't working there I still knew all the guys since my Dad was the shop foreman - I'm sure I know him. Let me know his name - or PM me if you don't want to post it......
PipeWelders no longer has a northern prescense - only in Florida. When they pulled out, my Dad took the employees and the customers and formed PipeTowers. They are still working out of SJ Marina and Avalon Pointe Marinas.
MM 175 w/ spoolgun
HTML code is On
