Bender change ?
Hello: I have a hossfeld #1 bender and a JD model 32 bender and I was thinking about selling both of them and buying a Hossfeld #2 bender in order to save space in the shop. I'm not sure if that is a good idea or not because i've never used a hossfeld #2 bender to bend pipe, any one have any recomendations. My model 32 makes really good bends and I dont want to go backwards.
Re: Bender change ?
think i would just stick with the model 32 and mount it vertical and put it on a roll around frame with a hydraulic ram...
No matter how stupid you think humanity can be, there will always be someone that exceeds your expectations.. |
Re: Bender change ?
Thanks Brucer: I do have the hydraulic ram, do you (or anyone) have an example pic of the vertical mount with roll around frame? And does the vertical mount make it hard to change the dies?
Re: Bender change ?
You could sell me the model 32
Re: Bender change ?
look around on http://www.offroadfabnet.com/forums/...=95&order=desc this is the section for benders, theres a few pics somewhere on there of guys mounting on a vertical stand..
i'm just using this as a reference http://probender.com/... i've seen pictures of people mounting jd2's and pro-tools 105 models vertical and using a harbor freight 8ton air/hydraulic engine hoist ram.. it doesnt seem like it would be to difficult, just have to get enough height for clearance of the ram to the floor.. looks like it would possibly be easier to work with in a vertical position.. if you decide to mount yours vertical, try to get the tubing level as it sets in the bender, that way you dont have to always add more angle to your total bends when using a magnetic angle finder...
Re: Bender change ?
Re: Bender change ?
Thanks Brucer: I know now I will keep the two benders, but im not sure about the verticle mount i'll have to do some thinking on that. Thanks again
Re: Bender change ?
A JD is really good for pipe and tube, much better than either hossfeld would be.
I do bend pipe in my hossfeld, but for railings and stuff like that- it works good for 3/4" up to about 1 3/4" schedule 40 pipe, in fixed radius bends, but it does deform the pipe a bit more (ovalize) than a JD would, and it takes more work and more fussing to get the bends right. If I was you, I would eventually sell the Hossfeld no. 1, and get the number 2, though, as its such a better bender. For everything else besides pipe or thinwall tube, a hossfeld rules. I have bent 1" x 4" flatbar (hot) miles of all kinds of round and flat and square, flat bar the hard way, angle iron, and lots more. A no. 2, bolted down, runs rings around every other bender there is, except maybe a Di-Acro no. 4, which retails for something like 4 grand these days. |
Re: Bender change ?
Thanks again Last edited by woodweld1; 06-20-2011 at 10:03 AM. |
