Old 06-19-2011, 07:09 PM
MWalden's Avatar
MWalden MWalden is offline
Welding Stainless to Steel
One of the projects I will use my new welder for will be bumpers for my Jeep. I have a design in mind but as of now I am not at all certain if this will work or not. If it is possible I will need to work it out prior to trying the bumper build.
Below is a crude illustration of part of the bumper. The dark represents regular weld steel in 3/16" and the silver represents the stainless area of unknown thickness for now.
Again, this is a crude representation and doesn't look exactly like what I have in mind but it should be close enough to give you the idea of what I want to do.
Is it possible to weld the stainless to the plain steel to make up what I have shown? Can it be done to where it is structurally sound?
What is the process necessary to achieve this?
Welding Newb
Airco "Bumblebee" 250 AC/DC [MA] Stick machine
Old 06-19-2011, 07:45 PM
Country Metals Country Metals is offline
Re: Welding Stainless to Steel
You can mig it with 309 but why would you use 1/2 steel and 1/2 stainless anyways?
Old 06-19-2011, 08:20 PM
MWalden's Avatar
Who said 1/2" anything? I said 3/16" steel and unknown stainless guage.
Welding Newb
Old 06-19-2011, 08:26 PM
NVW's Avatar
NVW NVW is offline
I don't think Country Metals meant inches but rather using each metal.
Leo
Old 06-19-2011, 09:06 PM
MWalden's Avatar
Ahh! I apologize. Ok, well, the stainless is simply for a certain"look" that I want to achieve.
Welding Newb
Old 06-19-2011, 09:50 PM
MarkBall2's Avatar
MarkBall2 MarkBall2 is offline
Use 309 stainless wire/rod for stainless to mild steel. If you use a MIG, use Tri-Mix gas. Don't worry about the black soot, it comes off easy with a quick wipe or brushing.
Mark
Craftsman 12"x36" Lathe
Enco G-30B Mill
Hobart Handler 175
Century 230 Amp A/C stick welder
Chicago Electric 165A DC TIG
Oxy/Acetylene set
PapaLion's Gate Build
Old 06-19-2011, 09:57 PM
MWalden's Avatar
Can it be done with SMAW? I have access to a Miller Cricket mig but my Airco 250a will be readily accessible all the time at home.
Welding Newb
Old 06-19-2011, 10:02 PM
sn0border88 sn0border88 is offline
For what your going to be using it for, you can weld it with any steel electrode just fine.
Have we all gone mad?
Old 06-19-2011, 10:04 PM
SMAW with a stainless steel rod needs a big learning curve. It is my last choice for welding stainless or any kind. If you have access to a DC stick machine, then get a tig conversion and a bottle of argon and Tig weld it with 309.
Old 06-19-2011, 10:05 PM
MarkBall2's Avatar
True, but the weld may "rust" or discolor if you don't at least try to use a stainless wire/rod.
SMAW, you would have to find the rod. If I remember correctly, I saw 309 rod online, but don't remember where.
Mark
Enco G-30B Mill
Hobart Handler 175
Oxy/Acetylene set
Old 06-19-2011, 10:53 PM
gordfraser gordfraser is offline
For that application id say you could use SMAW (which keeps it simple)
I did something similar with 316 lincoln red baron.
steel and stainless are very similar.
and if you are not so worried about the corrosion resistance then it i'll be fine.
you could probably use 7018.
dont forget the pics!
G
Old 06-19-2011, 10:56 PM
........ unless the stainless that you are going to weld is real thin.
16gauge might work with SMAW if you are careful, maybe a little thinner, but not much.
G
Old 06-20-2011, 04:25 PM
MWalden's Avatar
I don't know my steel gages very well but it will be about the thickness of the stainless steel food prep counters you see in restaurants.
I have access to a Mig but I would have to borrow it and get the proper wire. My Airco 250a AC/DC machine will be home in a couple of weeks.
Welding Newb
Old 06-20-2011, 04:27 PM
MWalden's Avatar
I have an AC/DC stick machine but I have no idea what the cost of a tig conversion would cost me and I bet it is out of my budget anytime soon.
Welding Newb
Old 06-20-2011, 06:39 PM
SmokinPRanch's Avatar
SmokinPRanch SmokinPRanch is offline
SMAW 309 rod. Any LWS should have it. As stated before, stainless stick welding takes practice...it is a different animal.
If it is a one off project might be better off fitting it up and paying someone to tig it. A full tig set up is gonna cost a few bucks.Of course when you're done you still have the tig equipment.
I've welded stainless/carbon with 6010 in "gotta have it now", low stress situations. Works, but definitely not the way to go on a project without constraints.
Al
A man is judged by what's between his legs...always ride a good horse
Miller DialArc HF
Lincoln Classic 300D
Thermal Arc 181i
Powermax 45
Scotchman Ironworker
(2) Bridgeports
Okomota Surface Grinder
AutoCAD 2010
Old 06-20-2011, 10:02 PM
MWalden's Avatar
Al
Well, this is a project for myself so its no hurry and no constraints. I definitely plan to practice a lot of this before I go for the final project.
Welding Newb
Old 06-20-2011, 10:16 PM
Cyberweld - Just rough pricing
WP17 torch - 95.65 http://store.cyberweld.com/db150ampairt.html
Tig/Stick adapter - 15.04 http://store.cyberweld.com/tigtopoad10.html
Free Shipping in US - 0.00
Total: 110.69
You will also need to buy, rent, or borrow a agron bottle and regulator from someone.
Old 06-20-2011, 10:25 PM
If you think you will be doing work in the future that will use the tig it is a good investment. If you do much stainless at all it's definitely the way to go.
Go with the 309 for carbon to stainless if you go with SMAW. Check the manufactures sites for parameters and tips. Try to keep the stainless as close to the carbon thickness as you can to keep washing in to a minimum.
BTW nice drawing. What are you using to cut the stock?
Al
Miller DialArc HF
Thermal Arc 181i
Powermax 45
(2) Bridgeports
AutoCAD 2010
Old 06-20-2011, 10:59 PM
MWalden's Avatar
Total: 110.69
That is extremely affordable! I figured hundreds of dollars. I thought I needed some kind of "high frequency" box?
Al
Thanks for the advice and it is well appreciated!
I probably won't be doing much stainless at all. If this project goes south I won't mess with it much at all again. This is just a vision I have in my head, and if I could pull it off, I believe it would really look sweet. I would have a "one of a kind" item.
I have no idea what I will be using to cut the material. I am just trying to gather info on this first so I can get the things I need to do this with.
I don't have any real equipment yet as this is waiting on me to first get my welder home, get service to it and then set up a small shop area. This could be months and months till I start this project.
As you can tell I am a complete novice and a bunch of stuff I need to build. I have welded before. I started with stick and then to Mig, but I have no developed skills.
Adding Tig would be awesome. Just another thing to start learning. Last time I Tig'd I was burning up the tungsten
I am nearly 50 years old and just starting to learn this. Mechanic all my life with some fabbing under my belt but not enough to brag about.
Welding Newb
Old 06-21-2011, 12:01 AM
MarkBall2's Avatar
Humpf............. 50 years old is just gettin broke in.
I'm 54, just got a lathe last year, a mill 1 month ago................
Never too old to learn something new. Go for it with the TIG if possible, if not 309 wire in the MIG. A hundred bux isn't much to spend to learn a new hobby. And once you learn it, work on mastering it.
Mark
Enco G-30B Mill
Hobart Handler 175
Oxy/Acetylene set
Old 06-21-2011, 06:47 AM
welds4d welds4d is offline
You don't need a hi-freq box to DC TIG, that would only be needed for AC. If you go with TIG, remember to connect your TIG rig to the Neg welder terminal. Whatever process you choose, the 309 filler is the best for that application. Don't be afraid to try the Stick, just get some scrap and try a few beads before moving to your finished project. Mild steel scrap is fine for practicing on.
Old 06-21-2011, 07:48 PM
MWalden's Avatar
Wow! Well, this is looking better and better! Thanks for the help!
Understood. So, as you said, use the DC terminals for the Tig welding and plug the torch into the DC negative terminal and run a positive ground? This leaves me with the same amperage adjustments as if I were sticking it?
How will the starting be done? Scratch start?
Maybe there is another area of the forum I should look at for these answers.
Welding Newb
Old 06-21-2011, 09:54 PM
"Field tig" (the adapter that I previously linked to) uses scratch start which is not a match strike, it is more of a touch and raise slightly. You only need to make a connection to enable amp flow, once started it will continue when you raise the tungsten off the metal. There are many sections on here and on the web about learning to tig weld. You will actually use less amps with tig then stick.
Stick - DCEP (electrode positive)
Tig - DCEN (electrode negative)
Your best bet is to get some steel 1/8" plate to run flat beads and flatbar to cut 6" lengths and start welding them together in a T joint, since this will be the same type of join you are showing in your picture.
Steel and Stainless Steel basically weld the same when tigin them.
Old 06-21-2011, 10:05 PM
MWalden's Avatar
Thanks! Just got out of the Tig Welding forum and was reading a lot of the posts there.
I got plenty of time to practice once I get the rig set up.
Welding Newb
Old 06-22-2011, 04:26 AM
fordman's Avatar
fordman fordman is offline
If it is just a bumper I would weld it with your regular mild steel mig wire... I have done it a lot and it works fine. Same with tig, I usually just use er70s2..
HTP Invertig 201
Lincoln Idealarc SP250
Miller 180 AC Stick
By farmall:
They should have held the seagull closer to the work, squeezing evenly for best deposition.
