Old 07-11-2006, 01:54 PM
ukmxer ukmxer is offline
Tig ali bumps in bead.
I am welding Ali 1.6mm with 1.6 rod and 2.4 tungsten on a 160 miller econotig acdc. The weld is going on OK but after I have finished and check my weld, there are tiny lumps in my weld pools giving it a bumpy feel and texture. I am used to using inverters and syncrowaves and have not seen this before. Is this because it is a cheapo welder without square wave technology or am I causing the problem.
thanks
Old 07-11-2006, 04:00 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: Tig ali bumps in bead.
could be a number of things...
is there any way to post pics of the problem??
...zap!
No Comment
Old 07-11-2006, 05:28 PM
Here a sample pic..
See attachment.
Old 07-11-2006, 05:53 PM
zapster's Avatar
Moderator
well from what i can tell..the last pic tells the story..
first off.... juuuust a little more heat...
and when you end the weld it looks to me that you need more "post purge" time...
set it at around 3 seconds and when you stop the weld don't move the torch untill the purge is over..sometimes i kik the pedal real quick if its a real hot one..just for the extra 3 sec...
...zap!
No Comment
Old 07-11-2006, 06:09 PM
Thx Zapster
I got it wrong then, I thought I was putting too much heat in. I had tried different flow rates on the argon but had no joy. I will try a little more heat tommorrow.
thank you for your help.
Old 07-11-2006, 06:13 PM
zapster's Avatar
Moderator
please let us know what you find out...
...zap!
No Comment
Old 07-11-2006, 06:16 PM
zapster's Avatar
Moderator
and by the way
you don't need a square wave machine to get fantastic welds..
check out the intake pics that i made
done with a Airco circa 1958..
square wave? whats that? lol
...zap!
No Comment
Old 07-11-2006, 09:33 PM
zapster's Avatar
Moderator
after reading and re-reading and reading the posts...
you mention only argon...
is that all you use?
you really should have a 75-25 tank of gas...
unless you're using a mixer...
straight argon is rather "cold" for aluminum...
thats why more heat is needed ..but you beat on the machine more than needed..
and clean the crap out of it 3 times beforehand with acetone..just for 's
...zap!
No Comment
Old 07-12-2006, 07:19 AM
BBchevy396's Avatar
BBchevy396 BBchevy396 is offline
Guest
75-25....... Ar/He ?
Old 07-12-2006, 10:58 AM
gnm109 gnm109 is offline
Originally Posted by zapster
and by the way
...zap!
Zap, you got a new friend for life! I too have a nasty old transformer welder (No Square Wave, Idealarc 250/250 TIG Stick Lincoln, ca. 1985). It's so nice to hear that someone else has a non-square wave machine and does well with it!
I saw your nice manifold job and it's as good as anything I ever saw at Rocketdyne and North American Aviation when I was working there.
In the old days of TIG, nobody knew a square wave from a donut and they still managed to build beautirful stuff that would pass X-ray and visual inspections.
Now I don't have to hang my head anymore! Thanks for that! Whoopee!
Old 07-12-2006, 11:45 AM
zapster's Avatar
Moderator
yes 75% helium 25% argon..
but in my guesstimation..i dont care for pre mixed gas..
still a little to "dirty" to me because of the helium..
thats why i like gas mixers..i like to run around 38% (ar) on aluminum....
...zap!
No Comment
Old 07-12-2006, 11:46 AM
zapster's Avatar
Moderator
always happy to help...
...zap!
No Comment
Old 07-12-2006, 03:10 PM
TubularFab TubularFab is offline
I find I like mid '80s era Lincoln TIG 300/300 way better than the synchrowaves (250, 350, 351) they have where I work. The old non-squarewave seems to hold an arc at much lower amperages, and seems to get more heat out of the same tungsten diameter than the millers no matter how you adjust them. So, I would have to agree with you Zap!
Old 07-12-2006, 09:42 PM
orphan68 orphan68 is offline
Guest
I have a mid 80's Cyber-Tig if you're interested.
Old 07-14-2006, 10:00 PM
zapster's Avatar
Moderator
well guys ...
the older machines are so simple to operate..
and they will give you great results with the right set up
the hobart i have now is a whole diffrent but the same animal...
but i'll get it figured out as soon as the gas mixer shows up
...zap!
No Comment
Old 07-15-2006, 12:19 AM
Roy Hodges Roy Hodges is offline
[quote=zapster]after reading and re-reading and reading the posts...
You know why argon is "Cold" on aluminum ? Because
Argon is 10 (ten) times as dense as Helium. Look it up
in a hand book the the big gas companies give out . I did .And you're right about the cleaning. it needs to be sterile.
[SIZE="5
"Yardbird"
Old 07-15-2006, 05:10 AM
chopper5 chopper5 is offline
well guys ...
...zap!
ZAP that is so true i think these new machines take some of the skill out of welding ,there real nice but i think the old machines run good you just got to up your game some
Chuck
ASME Pressure Vessel welder
Old 07-17-2006, 09:31 PM
guy-finnigan's Avatar
guy-finnigan guy-finnigan is offline
don't use acetone.. it can give you very porous welds on aluminum.. use methyl hydrate if possible
Old 07-17-2006, 09:45 PM
zapster's Avatar
Moderator
wtf?
listen partner..acetone will not give you porous welds in aluminum..
i oughtta know by now
geesh
i think your set up is responsible for porosity...
acetone does nothing more than clean the surface..and it evaporates and leaves NOTHING BEHIND!!
get with the program...and learn to weld then...
and i said so
...zap!
No Comment
Old 07-17-2006, 09:53 PM
oh really?.. so how much welding education do you have?
Old 07-17-2006, 09:58 PM
zapster's Avatar
Moderator
30 yrs..certified in mig (even though i have not touched one in 12 yrs..)
and TIG
go find the intake close-up thread and you tell me if i know what i'm doing..
dont **** me off..it was 108 in the shop today
and when you can weld like that let me know
...zap!
No Comment
Old 07-17-2006, 10:03 PM
ya i'm pretty sure i'm a certified aluminum mig welder and that's what i do every day all day and i've found out from experience that acetone gives porous welds.. maybe you're not trained to notice what a porous weld looks like.. i'm sorry that you never learned that.. oh ya.. all 4 of my welding teachers in college say not to use acetone
Old 07-17-2006, 10:07 PM
zapster's Avatar
Moderator
whatever..
i've never had a weld fail and i'm not about too
you just carry on with your method...
and so will i
have a nice day
..zap!
No Comment
Old 07-17-2006, 10:34 PM
smithboy smithboy is offline
Moderator
Both are common solvents however, acetone is the only one of the two specifically listed by lincoln and miller for cleaning aluminum. I have used acetone for years and never had any problems with it. Lincoln's website suggests cleaning aluminum with acetone or other hydrocarbon solvents.
Guy, do you have any more information about what your instructors say causes the porosity when using acetone?
http://www.lincolnelectric.com/knowl...nt/tigalum.asp
http://www.millerwelds.com/education...s/story59.html
Smithboy...
Old 07-17-2006, 11:23 PM
zapster's Avatar
Moderator
sorry to all i got
i suppose there are diffrent methods...
but...
i dont think its available at the local hardware store...
...zap!
No Comment
