Old 07-11-2006, 03:19 PM
stonebreaker stonebreaker is offline
How would you cut a circle?
I'm trying to weld a seat onto a stool I made out of some scrap. How would you go about cutting a circle out of a piece of 1/4" plate for a seat?
Stonebreaker
Graduate of the John Wayne School of Linguistics
Old 07-11-2006, 04:06 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: How would you cut a circle?
O/A torch...
...zap!
I am not completely insane..
Some parts are missing
Old 07-11-2006, 04:17 PM
MAC702's Avatar
MAC702 MAC702 is offline
plasma or oxy-fuel. What do you have available to you?
Old 07-11-2006, 04:41 PM
Ries Ries is offline
Make a simple compass style circle cutting attachment for either a plasma or oxy fuel torch. An old speaker magnet, a piece of round bar, and a couple of hose clamps.
Old 07-11-2006, 04:47 PM
TxRedneck's Avatar
TxRedneck TxRedneck is offline
I just use the torch. First, make a pattern of something round...anyway you want. Differnt methods. Best is if you use a round item the size you want. Then I get real comfy and I cut it by hand. I dont mess with them fancy dealies. THey are nice, but I dont bother spending the money. I had a pattern cutter at the college I attended. As an alumni I can use it anytime during the school year, but I moved away ... oh well
IF it Catches...Let it Burn
Old 07-11-2006, 05:42 PM
halbritt halbritt is offline
How about cutting many circles 3-4" in diameter in very thin sheet aluminum? I'm thinking of a punch and die of some sort.
-Heath
Old 07-11-2006, 05:58 PM
Roy Hodges Roy Hodges is offline
I think you could buy a hole saw for a drill,( or drill press ) or you might make a punch using apiece of pipe the correct o d , and sharpen the inside of one end to make a punch out of it, and weld a plate on other end to strike with a hammer.
[SIZE="5
"Yardbird"
Old 07-11-2006, 06:00 PM
zapster's Avatar
Moderator
hand arbor press and a custom made die by ...zap!
...zap
Old 07-11-2006, 06:22 PM
MAC702's Avatar
Do you want the circle or the hole? If you want the hole, and if it's the right size, I use the Greenlee electrician's conduit punches for that very thing.
