Old 07-12-2006, 11:15 PM
docbob docbob is offline
lincoln model ac225dc210/6 code 8399
this lincoln weldanpower has low voltage on the generator 110 outlets only
put out 90 volts 220 outlets give only 170 volts the welder works fine
i need to know how to get the generator to work ser# a9382352
Old 07-13-2006, 12:55 AM
MAC702's Avatar
MAC702 MAC702 is offline
Re: lincoln model ac225dc210/6 code 8399
Is this covered in the troubleshooting section of your manual? Do you have your manual? You can get it here: http://www.mylincolnelectric.com/Cat...nualsearch.asp
Also, while some here might be able to help, also give Lincoln a call while you wait for someone here that might know: http://www.lincolnelectric.com/products/service/
Old 07-15-2006, 03:28 AM
BobC BobC is offline
I haven't read the troubleshooting section of the manual, but the first thing I would try is making sure the fine weld current control is in the max position. In this type of machine the fine control rheostat controls both the weld and AC auxiliary voltage.
Also check the engine RPM. If you have a multi-meter that will measure frequency, you only need to check the frequency at your 115VAC receptacle. The engine RPM will equal the frequency in Hz times 60, for a 3600 rpm machine.
With no load on the machine, and the idle switch set to high RPM, you should read about 62 Hz.
Good luck.
HTML code is On
