Old 07-16-2006, 05:16 PM
EBFARMER EBFARMER is offline
Offset smoker
This is the smoker that was in the background of the bow press pics. I started it in Feb and finished the first of May. It is made from two old well tanks and the wheels are from old wheelbarrows. It turned out pretty good, however if I were to build another one I would probably look for some 18 or 20" pipe. The main reason is because the well tanks are a little bit thin and the pipe would hold heat better.
Old 07-16-2006, 06:03 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: Offset smoker
neet
now lets see...
i have some ribs and sausage that need what you have there...
hmmmmm
...zap!
No Comment
Old 07-16-2006, 08:02 PM
Stainless Stainless is offline
Re: Offset smoker
That's really nice. I've been looking at pics on the net to get ideas from and I've decided on the design you used. I was really interested in the vertical one but that would be a little top heavy. I'll be starting my smoker project soon but I'll be using 20" 5/16" pipe. It will be heavy but I have it available at work so I can save a lot of money there.
Old 07-16-2006, 09:41 PM
Re: Offset smoker
I think you will be way ahead using the pipe. I would also look at reverse air flow inwhich the heat and smoke come into the cooking chamber and pass under plates on the bottom then come back through the cooking chamber and exit through a chimney on the fire box side. These design is supposed to keep more even temps across the cooking chamber. Another good site to look at for smokers is http://www.barbecuenews.com/forum/default.asp. I learned a lot from there after I built this smoker and have several ideas to try on the next one.
Old 07-16-2006, 11:25 PM
Weldordie Weldordie is offline
Re: Offset smoker
Nice work. Thanks for the pics. Now... if I only had some brisket...
Old 07-17-2006, 01:05 AM
Roy Hodges Roy Hodges is offline
Re: Offset smoker
gives me an idea. i have 2 pieces of pipe , about 20" dia. -about 1/2" thick.(each about 2' long) that ought to be heavy enough ?
[SIZE="5
"Yardbird"
Old 07-17-2006, 07:07 AM
bigdogrider99 bigdogrider99 is offline
Re: Offset smoker
I built one for the house last year using a propane tank as the starting point. Mine is a gas-burner however. I get the smoked flavor using one of the cast iron wood chip pans. Actually it cooks great like that, I used two pieces of black iron pipe for burners.
If anyone decides to build using the propane tanks though make very sure the tank is purged completly. It will ruin your day/week if it isn't purged.
If you are not going to do it right...Why bother?
My retreat http://www.ford-trucks.com/user_gall...&albumid=20987
Old 07-17-2006, 07:08 AM
Re: Offset smoker
Oh yea the grill looks great.
Old 07-20-2006, 06:18 PM
kbnit's Avatar
kbnit kbnit is offline
Re: Offset smoker
That smoker looks nicer than the one I bought at the store. Great job.
I r 2 a perfessional
Old 07-28-2006, 11:02 PM
a_watts90 a_watts90 is offline
Re: Offset smoker
why does zapster have to sa zap after everything and what is a zapster anyways??? i kind of get tired of his crap. everything he says he ends it with zap. maybe i should start ending everything i say with bam or sumthin?
Old 07-29-2006, 12:38 AM
Re: Offset smoker
I'm glad you brought it up... I'm sick of the zap! thing, too. I know how it can get under your skin.
Kapow... bzzzt!
Old 08-04-2006, 12:09 AM
Washman's Avatar
Washman Washman is offline
Re: Offset smoker
Very Nice .... Superb job
Nicer than the stuff I see in the stores.
Washman
Old 08-04-2006, 05:41 AM
Joe H's Avatar
Joe H Joe H is offline
Re: Offset smoker
What's wrong with this idiot? Not you, Zap. I enjoy your posts, the ones that aren't extremely informative are quite entertaining.
I'm gonna start ending with fart sounds.
Oh yeah, great smoker! Very professional looking.
Old 08-04-2006, 07:28 PM
fwalz3's Avatar
fwalz3 fwalz3 is offline
Re: Offset smoker
Don't listen to them, zapster! I, for one, always enjoy your posts; knowledge mixed with a bit of humor keeps things interesting!
...zap! ...zap! ...zap!
Sure, I can fix it... I got a welder!!!
Old 11-20-2006, 04:54 PM
valltex76689's Avatar
valltex76689 valltex76689 is offline
Re: Offset smoker
Hello,
I have not looked at the above mentioned link, but I do have some experience here as I built one like what is described. Works "GREAT" if you truly love the smokey flavor. This design forces the smoke to linger over the food and in the pit longer all depending on the dampers and flus. Here are a few construction pics of mine, I will post more pics when I finish painting it.
If anyone has any questions by all means drop me a line.
Note: I built the trailer, pit, smoker box and wood box from some sketchy ideas in my twisted cranium.
In image 511 you can see the false floor. I used 1/8" sheet and built some support stands out of 3/4" 14ga square tubing.
Stacks are 6" thin wall pipe.
Burned almost a complete 44lb roll of wire on this little project.
Old 11-20-2006, 05:02 PM
zapster's Avatar
Moderator
Re: Offset smoker
My Goodness!!
Bobby Flay will be hunting you down in no time!
good job!
now get it going and drive around diffrent neighborhoods with ribs and everything cooking away...
make everyone get that sweet smell in their noses and look out!!
...zap!
No Comment
Old 11-20-2006, 05:08 PM
Re: Offset smoker
here are a few more pics.
I also forgot to add that this little guy has 6 removeable racks 4 for smoking big meat and 2 for hot dogs and the like.
When finished it will also have a 30 quart fish/turkey fryer on the back, with a toolbox and ice chest storage on the front.
Old 11-21-2006, 12:30 PM
RJ Lindblom RJ Lindblom is offline
Re: Offset smoker
Some day. Those are both sharp setups
Old 11-21-2006, 08:01 PM
drivesector drivesector is offline
Re: Offset smoker
I want a smoker
Drivesector
Hobart Handler 140
Hobart Handler 180
Ready Welder 2
Hobart Air Force 400
Airco Stinger 225
Of all the things I've lost, I miss my mind the most."OZZY"
Old 11-21-2006, 08:39 PM
scott brunsdon scott brunsdon is offline
Re: Offset smoker
I love these BBQs you guys make.
Why are they called 'offset smokers'?
Old 11-21-2006, 09:14 PM
zapster's Avatar
Moderator
Re: Offset smoker
because the wood/charcoal mix is on one side...
and the food of choice is on the other..
and the heat and the smoke "radiate" around the food and thats how the food is cooked..
the food is not in direct contact with the heat source
however it takes many hrs of cooking to get what you want..
...zap!
No Comment
Old 11-22-2006, 04:10 AM
Re: Offset smoker
Originally Posted by drivesector
I want a smoker
I have had a couple of people tell me I should take orders and build for the public. I don't really think the public is going to spend what I would have to have. Can we say labor intensive and the 1/4" plate isn't cheap either.
Zap,
depending on what you want I can cook suprisingly fast with that, but if you want fall off the bone it does take some time.
Building mudtanks and other oilfield equipment day by grueling day.
Victor preformer
Millermatic 251
Miller Thunderbolt 225
Too many grinders and the like
Gone but not forgotten Miller Bobcat 250
Comming soon Lincoln Ranger 250
Old 12-14-2006, 11:31 PM
paintman paintman is offline
Re: Offset smoker
we built one last year out of an old compressor tank,250 gal,on a trailer..sold it on e-bay for 3050.00$it started as a ffa project
