Old 07-18-2006, 06:54 PM
99blackzr2 99blackzr2 is offline
how do these look?
i have less than 30 minutes of welding expierience.tell me the good and bad.i am starting my welding classes next month at my tech college.
Old 07-18-2006, 06:57 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: how do these look?
thats mig i presume...
not bad at all..
who set up the machine?
...zap!
I am not completely insane..
Some parts are missing
Old 07-18-2006, 07:00 PM
not bad at all..
...zap!
just me.its a lincoln power mig 215.
Old 07-18-2006, 07:03 PM
zapster's Avatar
Moderator
good job my friend
next test..
weld something together
...zap!
Old 07-18-2006, 07:10 PM
prop-doctor's Avatar
prop-doctor prop-doctor is offline
looks good for the first time next,pipe to flat plate, pipe to pipe flat to flat and your on your way oh and do a 90 keep up the practice. learn all ya can at school and be safe
Old 07-18-2006, 07:20 PM
thanks
Old 07-18-2006, 07:21 PM
whats a 90?
Old 07-18-2006, 07:34 PM
two flats next to each other to make a 90 or right angle
Old 07-18-2006, 07:57 PM
pipe to pipe.i was off to one side a little to much.
Old 07-18-2006, 09:12 PM
LuzRD LuzRD is offline
nice looking beads
in the first pic the bead on the left looks best, the other two look a little religious (got a crater, and what looks like a little porosity towards the end of the other bead) holy beads like that may be the result of poor gas coverage. what were all your settings?
a little off center on the pipe, if your having trouble seeing the joint you may want to try a lighter shade on your hood (comfort and vision!). if not keep up the practice, your doing good. = }
Old 07-18-2006, 10:11 PM
Originally Posted by LuzRD
nice looking beads
the porosity seemed to happen when gusts of wing blew in the garage.i am not sure what the settings were.i went by the chart under the cover.
Old 07-18-2006, 11:38 PM
yup, gusts of wind will do that = {
good work!
Old 07-19-2006, 09:29 PM
good work!
thanks
Old 07-19-2006, 09:32 PM
zapster's Avatar
Moderator
try to do a tube like that without starting and stopping...
test #3
remember..one must look in front and in back of the weld at all times...
...zap!
Old 07-19-2006, 10:39 PM
test #3
...zap!
i will try tomorrow and post pics
Old 07-20-2006, 09:15 PM
good job my friend
next test..
...zap!
this better?
Old 07-20-2006, 09:27 PM
zapster's Avatar
Moderator
looking good my friend...
keep it up...
...zap!
Old 07-20-2006, 09:35 PM
keep it up...
...zap!
thanks.i got some scrap plate from work today.the metal looked flaky on the other side.is that normal?
Old 07-20-2006, 09:42 PM
zapster's Avatar
Moderator
yeah pretty much..
theres no gas coverage back there
...zap!
Old 07-20-2006, 10:09 PM
yeah pretty much..
...zap!
dont people usually find smaw harder to do than gmaw.i picked up a ac225 lincoln today from a guy at work fo $50.00 today.i can make better looking beads with stick welder.is that normal.i have always heard stick is harder to learn.
Old 07-20-2006, 10:14 PM
zapster's Avatar
Moderator
i'm thinkin' your just a natural..
some people just "meld" with a welder...
post pics of what you welded with the stick and what amps and rods you use...
size etc..
..zap!
Old 07-20-2006, 10:34 PM
size etc..
..zap!
i will tomorrow after work.i will post a pic of my girlfriends weld also she surprised me how good she is. her first bead of weld is almost as good as mine!!!!
Old 07-21-2006, 05:50 AM
chopper5 chopper5 is offline
what gas are you useing?
and your welds look good
Chuck
ASME Pressure Vessel welder
Old 07-21-2006, 06:11 AM
wello's Avatar
wello wello is offline
Moderator
looking good I have a tradesman at work that would be doing good get welds like that
if you keep going like that once you start tech you'll have a bright future in the trade well done
Creative metal
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Old 07-21-2006, 06:17 AM
thanks.i am using 75 argon/25 co2. i think its called c-25
