Old 07-19-2006, 08:06 PM
bbecky1234 bbecky1234 is offline
Any left handed welders?
I am posting this for my brother. He is taking classes to be a Navy Sea-bee. He is the only left handed person on base apparently and his instructor told him to just do everything opposite everyone else. Then the instructor said there was a trick to welding left handed, but he does not know what it is. Can anyone help?
Old 07-19-2006, 08:18 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: Any left handed welders?
left.. right... either foot... it dont matter
drummer
...zap!
No Comment
Old 07-19-2006, 09:00 PM
ironman7 ironman7 is offline
I have been welding for 24 yrs.I'm left handed,there is NO tricks! Over the years I have also learned to weld with my right hand. You can't always use your prefered hand! Always have a backup. What happens if you loose both hands?
Old 07-19-2006, 09:05 PM
TEK TEK is offline
I too am a southpaw. Been welding over 30 yrs. Doesnt matter that I ever noticed. Can Do!!
Old 07-19-2006, 09:06 PM
zapster's Avatar
Moderator
torch in mouth..filler in foot?
no thats no good..need a mask..and i'd imagine it would get quite uncomfortable...
well i guess your screwed if you tig..
oh well
...zap!
No Comment
Old 07-19-2006, 09:07 PM
Thank you very much, I will let him know. He is very nervous about doing a good job and passing his test on Fri. Thanks.
Old 07-19-2006, 09:10 PM
zapster's Avatar
Moderator
look if he has it in him he has it in him...and he will pass the test
only the best now..
...zap!
No Comment
Old 07-19-2006, 09:17 PM
smithboy smithboy is offline
Moderator
I am a rightie, and all my beer mugs are left handed...I just had to adapt.
Smithboy...
Old 07-19-2006, 09:28 PM
gnm109 gnm109 is offline
He should be OK. I weld mostly left-handed but sometimes I change hands if necessary. Shouldn't be any difference at all.
Old 07-20-2006, 12:44 AM
TEK TEK is offline
If he is left-handed he's already better than 88% of the people he's training with. We are all gifted, ya know---
Old 07-20-2006, 07:59 AM
littlefuzz's Avatar
I once switched the polarity on the mig welder of one of our new guys "welder", whatever. And when he said something was wrong we told him it was setup for welding left-handed. He never did figure it out, but he knew everything there was to know about welders.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-20-2006, 10:21 AM
DDA52's Avatar
DDA52 DDA52 is offline
I am a lefty welder, and also weld righty. They made me certify with both hands when they caught me shifting hands once. I find it much easier to be able to use both. Just makes it much easier to find a comfy position. Myself, I don't do anything opposite from left to right. I'll keep the same weave and bead progression.
Old 07-20-2006, 03:43 PM
weldrwomn weldrwomn is offline
Left to right, right to left, either right or left-handed....shouldn't matter if you are a welder/fabricator that is worth your salt.
Old 07-20-2006, 04:00 PM
prop-doctor's Avatar
prop-doctor prop-doctor is offline
yeppers can I weld both ways does help when in the confines.. have a friend hes a lefty, but plays guitar right handed,, but hammers lefty,, and can weld both ways. now ifya bro can weld right handed life is good.. practice practice
Old 07-20-2006, 11:09 PM
PoisonPancakes's Avatar
PoisonPancakes PoisonPancakes is offline
Left handed. I kept getting confused when I was first learning cause I do everything with both hands and I would forget which hand I'm welding with.
Old 07-24-2006, 06:03 PM
kbnit's Avatar
kbnit kbnit is offline
Should learn how to weld left hand and right hand. And last I checked, the certification checklist only speficies position (flat & parallel, vertical up progression, etc), there is no recording of what hand did the welding. There'll be times you get into a tight spot and will have to shift hands. Best he learns it now.
I r 2 a perfessional
Old 07-24-2006, 06:17 PM
kbnit's Avatar
Yup, just checked AWS B2.1, Specification for Welding Procedure and Perfomance Qualification. Which hand is used is not considered a variable. Qualified with one hand, qualified with both.
Old 07-24-2006, 06:40 PM
gmc1999 gmc1999 is offline
I'm a southpaw also, but we are in our right mind.
MILLER ELITE WELDING HELMET 29 ROADSTER
MM 251
Lincoln Precision Tig 225
Weldtech Cooler
