Old 07-21-2011, 04:03 PM
Thiel-Metal-Fab's Avatar
Thiel-Metal-Fab Thiel-Metal-Fab is offline
is this plasma worth 400.00
is this hypertherme worth 400.00 he says its in good condition , i would like to find out soon , because i dont wanna miss it , if its a good deal ? sale-n2dhk-2500180366@craigslist.org
>Innovations are what i leave behind for History<
Old 07-21-2011, 05:06 PM
jimcolt jimcolt is offline
Re: is this plasma worth 400.00
I'd like to help...but the only link you provided is to reply to the seller....cannot view the item from that! What model.....does it work?
Jim Colt
Old 07-21-2011, 05:22 PM
Lanse Lanse is online now
The link didnt even work for me...
But Id assume that a working hypertherm for $400 is a good buy. Heck, Id do it, I could use a plasma cutter
Good luck dude! If you go check it out, just make sure EVERYTHING works and it hasnt been abused or anything
"Overkill is an often under-rated achievement" -Will Hayden
HTP Mig 2400
Hypertherm Powermax 45
Lincoln Precision Tig 225
Longevity StickWeld 250
Hobart Stickmate AC/DC
Hobart Handler 187
a.k.a ChuckE2009 on Youtube
Old 07-21-2011, 06:56 PM
brucer's Avatar
brucer brucer is offline
link doesnt work... you linked the sellers anonymous email link....
when you sitting on the ad page, copy and paste the address at the top of the page with the
http:// in it.. like this http://kansascity.craigslist.org/tls/2502775907.html
some of the older plasma cutters you have to watch out for... i seen an older unit that looked new, but needed a torch that cost near what they were asking for the plasma cutter..
No matter how stupid you think humanity can be, there will always be someone that exceeds your expectations..
Old 07-21-2011, 08:20 PM
Mick120's Avatar
Mick120 Mick120 is offline
For $1000 you could buy a new Powermax 30....complete with warranty.
More power, better technology, better system.
CIG 320SP pulse mig
Mitech ACDC315P
Samson 510 CNC plasma table
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 07-21-2011, 10:03 PM
Welding_Swede's Avatar
Welding_Swede Welding_Swede is offline
Maybe this will give you some idea.
Just picked up a Hypertherm Max42 (yeah, its 15 years old) off CL for $300.00 including half a dozen retaining caps, electrodes, nozzles and swirl cups. Seller said it was not working and it turned out to be the torch head safety switch for the retaining cap.
Used it tonight to cut some 1/4" aluminum for a truck repair. Works great. I ordered some shielded consumables for the torch from my LWS so I can drag with it but I have no complaints about the performance.
Hard to go wrong for 3 bills.
Eric
Old 07-21-2011, 10:14 PM
Part II:
Found the CL link that you were asking about. Its a Hypertherm 190c and I'm pretty sure its recommended cut is like 1/8" on mild steel with a max severance of 1/4".
If it were me, I'd keep looking. The only reason I picked up the MAX42 was because I needed something in that class range immediately and the guy was down the road and it was only $300 and my tanks are almost empty. So, it was just one of those things. Had it been a lower current machine, I wouldn't have even considered it.
E
Old 07-21-2011, 11:38 PM
Originally Posted by Welding_Swede View Post
Part II:
E
sorry about that guys. i must have been sleeping when i posted. welding swede has the link posted. thanks for all the help so far. ... so this plasmas pretty old then. i really wanna get a big enough one right away. so i dont end up having to upgrade 3 times. what if i offered 325.00 and see if he bites. im sure i could always sell it for that?
Old 07-21-2011, 11:46 PM
http://milwaukee.craigslist.org/tls/2500180366.html........ sorry heres the link.
Old 07-22-2011, 12:15 AM
Yeah, that is pretty small...
Personally, Id save my money. I got about $500 in my torch setup, and It was all brand new (except for the tanks and cart), and works great. It can cut way thicker than that plasma, plus weld and heat. I think that was worth the extra $100. Well, good luck whatever you do
HTP Mig 2400
Hobart Handler 187
Old 07-22-2011, 07:31 AM
The Powermax190 was manufactured by Miller for Hypertherm up until about 1 year ago. It is a 12 amp plasma with an onboard compressor. This unit was dsigned for sheet metal work...and does a decent job on materials thinner than about 1/8". It can sever 1/4" at very slow speeds......and at very low duty cycles.
It is a good unit if its thickness range is where you are planning to use it....great for HVAC and roofing installers, etc. It is worth the money if purchased for the intended use....but it is not a good plasma for someone doing general metal fabrication.
Jim Colt.
Old 07-22-2011, 09:03 AM
Jim Colt.
thanks for the info jim , great to have some one on the site that knows hypertherm !
i was hoping it was at least a 30amp . but i know very little about plasma's . so its no suprise to me that its only 12amp . ill keep watching craigs list for a deal and post here before i jump on it .
Also is there any perticular model i should look for ? we have a miller spectrum at work and i really like it > (dont know the amps either ) . but theres no way i could afford that machine . id be looking to cut up to about 1/2 - 5/8" thick steel etc .
id really like to get a Hypertherm though
thanks for any input
Old 07-22-2011, 09:42 AM
http://madison.craigslist.org/tls/2488721719.html okay found this thermal dynamics cutmaster for 800.00 or best offer . worth looking into ? say it has less then a hour . wonder how much it was new .
Old 07-22-2011, 10:09 AM
Watch for a Powermax600 (40 amps) Powermax900 (55 amps) or Powermax1000 (60 amps)......these are all very strong but older generation Hypertherm systems...there are many in the field so they pop up on the used market occasionally. There are over 55,000 of the 600's out there.....and I have seen them in the $500 to $600 range on Craigslist.
Jim
Old 07-22-2011, 10:11 AM
You can buy a brand new Powermax30 for around $1000 (online prices)....the 30 is a bit more powerful, will have a new machine warranty, and will provide much longer consumable parts life. Occasionally you will find a used 30 on the market.
Jim
Old 07-22-2011, 12:08 PM
Jim
okay , sounds like i just need to be patient and the right deal will come along . i check craigslist every day , so somethings bound to come up !
Old 07-22-2011, 06:33 PM
One of the tools I use for Craig's is a search aggregator like crazedlist.org. You need to have Firefox to use it but I find that it works very well. I can bring up the whole state in a matter of seconds if I'm looking for a certain machine.
If you're not already using something like this, give it a try. Its helped me find some killer deals.
Eric
HTML code is On
