Old 07-30-2006, 06:33 PM
dozer dozer is offline
Anyone have info on this old beast?
Does anyone have a schematic (wiring diagram) for this old beast of a Hobart?
(pic attached)
I was told it was WW2 Navy vintage. Engine is a Chrysler Industrial 6-cyl flathead. Nameplate is pretty worn; but it -looks- like it says 300 amps; and this number: "DW14457". Can't read anything else on it.
Still welds like a champ!
But the auto-idle assy run by the solenoid has fallen apart from age; and some of the light-gauge control wires behind the switch look real iffy...and I'd like to fix that stuff. Would also be interested in possibly reworking the aux-gen portion to put out AC. Rainy-day kind of project, for sure...
Plus, I'm just kinda nutty about having complete schematics for anything I own...
If anyone knows the right model# for it; or even has the manual and could copy/mail schematics, that'd be great.
Richard
ps; hmmm...there isn't any field for 'browse' under "attach files" ?? Maybe it'll show up in 'edit' after I post...
Old 07-31-2006, 04:43 AM
littlefuzz's Avatar
Re: Anyone have info on this old beast?
Looks kinda like one I got in the barn. Mine will run but not weld. The generator part works. I just ain't fooled since I bought my new one. I'm sure someone on here can help ya, I ain't got a clue. Will it run?
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-31-2006, 05:37 AM
Diverbill45 Diverbill45 is offline
Richard, ......... Check out Hobart's web site and see if you can get the information you're looking for.
I did this, on Lincolns web site, when I purchased an older Lincoln SA200 years ago and got all the information I needed.
Another thing, I'd suggest, is take the model # into the local welding supply store that deals with Hobart products and see if they can get you what you need.
Hope this helps.
Before I forget, welcome to the site. I live north of you around the Albany area. Was through the GP area a few weeks ago, heading south to LA to visit my son for a week. Glad to be back home and away from all that traffic.
Old 07-31-2006, 10:06 AM
howdy Fuzz,
Like I said, it welds great...i.e. it runs.
On yours, check the main brushes on the back end.
Mine wouldn't weld when I got it; and it was just the brushes 'hung up' in the holders from sitting so long. A little back-and-forth to loosen 'em, and it's been welding ever since.
Hmmm....now that I think of it, I later had a problem with the polarity switch too. On mine, it looks like a breaker. Luckily, those old switches were -screwed- together, not riveted! I was able to take the switch apart and fix it.
Diver, I don't -have- a model# !
Can't read anything on the plate. I'll go to the Hobart site and email 'em the pic and that "DWxxxx" number tho, and see if they have a miracle worker there...
Old 07-31-2006, 12:09 PM
DDA52's Avatar
DDA52 DDA52 is offline
Hobart may not have the info since the break up. They passed all the big stuff to Thermal. They might have the info if Hobart doesn't.
HTML code is On
