Stuck bolts
I'm currently in the process of replacing the u-joints on my aerostar. I'm having trouble with these bolts. I've soaked everything in PB-blaster for the first half of the day and haven't made any progress. I tried using a breaker bar and a scissor jack + a wrench. Nothing is working for me. Is there any tips or tricks I'm missing here?
I'm a Hoss, and a Boss. |
Re: Stuck bolts
Heat and an air ratchet!
Re: Stuck bolts
Heat the flange that the bolt threads into. Use an O/F torch, a bernz-o-matic won't get hot enough.
Re: Stuck bolts
Heat, then cool quickly with a wet rag. Repeat 4-5 times. Then try the pb blaster.
Re: Stuck bolts
heat the bolt, then touch a crayon to the threads on the backside. the wax will draw up the threads.
Dynasty 200DX Passport plus w/ spoolmate 100 victor 315c oxy/(act and prop) Miller digital elite milwaukee power tools |
Re: Stuck bolts
I agree with the heat treating process described above. If that doesn't convince it to turn loose, try hitting the flange several times with a BFH while aplying torque with a wrench. You may need to jack and block the rear wheels off the ground so you can rotate the shaft to hit the flange at each bolt as you loosen it. Use plenty of penetrating fluid after the heating. If that doesn't work, get a bigger BFH. Heat and Beat should make it come loose. I find a few choice cuss words seem to help alot in extreme circumstances.
These may need to be a string of multi-syllable words as your garden variety plain ole four letter words may not be sufficient in this case. Just make sure the younguns aint around if you have to resort to these measures.
Re: Stuck bolts
Member, AWS Lincoln ProMIG 140 Lincoln AC Tombstone Craftsman Lathe 12 x 24 c1935 Craftsman Commercial Lathe 12 x 36 c1970 - - - Ask for a wrench and someone will offer you a grinder. I'll just keep on keepin' on. |
Re: Stuck bolts
get it nice and hot with torch. dont cool it with wet rag your not trying to shrink the metal after you get the bolts out let it air cool i've been working on cars 20+ years
Re: Stuck bolts
Got it fixed. Just heated the round part with a rose bud then used a no name wrench an a mallet to knock them loose (Didn't want to ding up my craftsman set)
I had to make a trip back to the store, autozone sold me the wrong repair part. Thanks for the advice. And here's the old POS part.
Re: Stuck bolts
Ford flange bolts are just TIGHT.
Start with a "real" USA top quality wrench, turned so that the "overhang"is towards the flange. Put heavy pressure on the wrench and then hit the wrench with a "slugger" to break the bolts loose. Then go after the bolts with a "real" 12-point USA socket to turn ‘em out. Yeah, you could apply some heat at the flange, or at least strike it there a few times. Good Luck Edit - Never mind, reply #9 posted while I was typing. Last edited by denrep; 08-29-2011 at 08:09 PM. |
Re: Stuck bolts
![]() - Mondo
Re: Stuck bolts
As this is as good a place to give this tip after the fact as it may be, store it up for future use. some places you can't use a torch, but you can still heat with a arc welder and a carbon rod. Set your carbon on the bolt and place you ground near by. you can put it on the other end if you can get to it or you can latch it on close. you get things hot and stick beeswax to it and thing will near fall out on their own. well that last part might be a tad stretch, but not by much.
Re: Stuck bolts
Applying anti-seize products on fasteners in driveline components is not recommended. Buy new bolts & apply loctite (blue). 'cause losing a driveshaft really sux... BTW, anti-seize compounds are NOT lubricants....
-at the job- Miller Dynasty 200DX Miller Syncrowave 350 MillerMatic 250 Millermatic 350 Miller Bobcat 250 Lincoln AC225 Miller Spectrum 625 Plasma -at home- Everlast PP256 Longevity WeldAll 256PI 'slow is smooth, smooth is fast' Last edited by ASE_MasterTech; 08-29-2011 at 11:28 PM. |
Re: Stuck bolts
I didn't use any loctite or anti-seize for the bolts. I put a dab of anti-seize around the holes in in the u joints to make it fit together better. I will probably end up buying new bolts later this week.
Re: Stuck bolts
You replaced those? Shoot...you could have gotten another 15-20 feet out of them. ![]() ![]() Drive line components WILL most definitely loosen up and come apart on their own. I have had it happen on class 8 trucks all the time when they don't use good threadlocker.
QamuIs Heg qaq law' lorvIs yInqaq puS
Re: Stuck bolts
In place of heat, if it's unavailable or can't be used, a sharp hit on the bolt head while torque is being applied to the bolt will break them free.
Leo |
Re: Stuck bolts
I agree with using loctite on the way back in.
And I usually use a little heat, but I have had good luck in the past with an impact gun with a shallow 12pt, 12mm socket on an extension. You can usually get the bottom two bolts, then you have to rotate the shaft to expose the other two. |
Re: Stuck bolts
I'm not sure heating the flange was a good idea. There is a seal near by.....
I usually use a good wrench and a sharp hit with a heavy hammer. It'll either come loose or break it off. Then you go to plan B.
My name's not Jim.... Syncrowave 200 Millermatic 251 w/bottle mod Spoolmatic 30A Maxstar 150s Cutmaster 81 Jet JTM-1 mill Jet GH-1340-W3 lathe |
#19
Re: Stuck bolts
I have never had then stick so bad I couldn't just use my big breaker and custom shaved down 12 point.
#20
Re: Stuck bolts
Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant." |
#21
Re: Stuck bolts
Red Locktite! They aren't? You should tell that to Permatex Corporation. Appearantly they don't know. http://www.permatex.com/products/aut...ubricant_a.htm
Member, AWS Lincoln ProMIG 140 Lincoln AC Tombstone Craftsman Lathe 12 x 24 c1935 Craftsman Commercial Lathe 12 x 36 c1970 - - - Ask for a wrench and someone will offer you a grinder. I'll just keep on keepin' on. Last edited by Mondo; 08-31-2011 at 08:50 AM. Reason: Format corrections |
#22
Re: Stuck bolts
U-joints are a wearable item that require replacement on occasion & red Loctite usually needs heat for removal. Applying heat will not only weaken the metal & may also distort the flange (shouldn't we know this already, this is a 'welding forum' right??), and also may require nearby seal replacement (as previously stated). Use blue, blue, blue...
-at the job- Miller Dynasty 200DX Miller Syncrowave 350 MillerMatic 250 Millermatic 350 Miller Bobcat 250 Lincoln AC225 Miller Spectrum 625 Plasma -at home- Everlast PP256 Longevity WeldAll 256PI 'slow is smooth, smooth is fast' |
#23
Re: Stuck bolts
KROIL from kano labs. makes pb look like missippi mud. I have used it on many 'impossible' theads including Mauser and 1903 Springfield barrels. Driveline/exhaust components are a breeze compared to 70-80+ year old battle rifles.
When any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you must not see, this you are forbidden to know," the end result is tyranny and oppression, no matter how holy the motives. |
#24
Re: Stuck bolts
The Locktite Red # 271 softens when heated to 500°F. Kinda warm for seals, but it is easy to heat a small localized area to that temperature with a dinky Bernz-o-Matic pencil torch. 500 degrees isn't going to appreciably distort or weaken the flange. Once heated the bolts break free easily.
#25
Re: Stuck bolts
Unless specified by the manufacturer NEVER USE LOCTITE. The Permatex corporation would lead you to believe you can put Loctite on your scrambled eggs, use it for diaper rash, and erectile disfunction
![]() ![]() ![]() Proper torque will hold the fastener in place. You may have noticed that the cap screws in the u-joint were fine thread. Fine thread fasteners are designed for higher torque values, and thus higher clamping power. On the subject of anti seize compound...................anti sieze is a lubricant! While it won't cause a fastener to loosen with time, it will lubricate the threads causing improper torqueing. You'll apply more torque than specified fpr the fastener because it's lubricated. Your torque wrench won't know it's lubricated, but you'll exceed the force required to properly torque the fastener. and maybe stretch i,t or break it.
