I bought a chicago electric dual mig 131 a few years ago. I have a problem with the mig spool unraveling when I put a new roll of wire on it,also when I pull the trigger on the gun the mig wire roller keeps rolling and unraveling while i'm welding. Can you fix this?
Re: Mig spool unraveling :/ Please help!!
I have not see the inside of one of the HF machines but I have seen some import machines that cannot retain, that is apply enough tension to certain spool sizes to keep them from unraveling. Inspect the shaft/axle for the wire spool when you tighten it. It must apply some tension to the roll or it will birdsnest on you.
Tighten the drag on the spool.
Usually a nut or screw in the center hub of the spool axle.
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce. Prophet Mohammed, womanizer, child molester and ruthless killer? |
