Old 09-06-2011, 12:09 PM
Ducman82 Ducman82 is offline
Tig electrode sharpener? any recommendations?
Hey fellas.
Im in the market for a good sharpener thats not a thousand dollars, but good for the at home/ small shop work environment. what do you use? pros cons?
thanks alot!
Old 09-06-2011, 12:46 PM
Donoharm's Avatar
Donoharm Donoharm is offline
Re: Tig electrode sharpener? any recommendations?
so you're doing some orbital welding?
www.inoxworks.eu
Old 09-06-2011, 01:17 PM
Bob the Welder Bob the Welder is offline
A very simple, cheap and easy to use sharpener can be bought from..............I hate to say it...................Harbor Freight! http://www.harborfreight.com/catalog...lade+sharpener
Remove one guard that encloses the diamond wheel, chuck your tungsten in a drill and have at it. You can put any angle you want on very easily and can blunt the points if you want and use it to cut your tungsten to length.
I've used one for about 2 years now and love it. Be sure to use a 20% off coupon!
“There’s class warfare, all right, but it’s my class, the rich class, that’s making war, and we’re winning.” Warren Buffett
American by birth, Union by choice! Boilermakers # 60
America is a Union.
Old 09-06-2011, 01:29 PM
shovelon's Avatar
shovelon shovelon is offline
If you want something multipurpose. This is it. I have 2 of them. When the belt gets dull, flip it over and use it some more. I use this sander not only for sharpening my tungstens, I grind, radius, chamfer, and deburr parts with it also.
The cost about $400 bucks. Bought mine about 20 years ago and other than having to reskin the backing plate they are holding up like a champ. I still believe they are made in USA.
"Nothing welded, nothing gained."
Miller Dynasty700DX, 3 ea. Dynasty350DX, Dynasty200DX, ThermalArc 400 GTSW, MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250, Hypertherm800
GaryJohnson2016
Old 09-06-2011, 01:56 PM
thats not a bad idea....
Lincoln Precision TIG 225, with Coolmate water cooler.
Old 09-06-2011, 02:02 PM
fdcmiami fdcmiami is offline
this is not a home item but i guess it could be; i keep it in my gang box on the truck. you can rest it on a flat surface upside down and lock the trigger to the on position and grind away. it's a little expensive but i see them on CL sometimes. beats the 7 in milwaukee grinder.
Amazon Amazon
Old 09-06-2011, 02:05 PM
Bosch 1274DVS 3 x 21 in. Variable Speed Belt Sander ; amazon links verboten it would seem.
this is the unit.
Old 09-06-2011, 02:22 PM
skelley521's Avatar
skelley521 skelley521 is offline
I am getting ready to test the 2% lanthanated.
I have free samples coming from various vendors. They are pre-ground with different tapered angles. Some fine point and some are blunt.
I requested the standard 20RA smooth ground finish over the 10RA mirror polish.
Can't wait to test out the different included angle per taper to find out how they hold up to the different amperage.
Edit: I just use a 6" sanding pad on a grinder, 80 grit on it at the moment. Also have a StiloTig enroute also.
Semper Fi
Jesus may have been a Carpenter, but his dad was a Millwright
" A grinder and a can of paint, will make a welder what he aint' "
I've done so much, with so little, for so long, that now I can do anything with nothing!
Old 09-06-2011, 02:50 PM
welds4d welds4d is offline
I normally just use a belt sander as well. You can chuck your tungsten in a drill if desired. I have a little home-made gizmo that another welder turned me onto years ago, made out of a piece of small SS tubing and a bent piece of TIG wire...looks like a slide whistle....the tungsten rotates from the friction of the sander or grinder...
skelley521's Avatar
Hey Bob, I've been eyeballin' the blade sharpener out for some time now.
How much of the wheel face has a diamond surface and how many time can you sharpen before replacing?
Semper Fi
Old 09-06-2011, 03:13 PM
Mine has a band of fine diamond coating that is 9/16" wide on a 4" diameter wheel. I bought an extra wheel with mine (about $10 IIRCC) but have not had to replace mine yet. I have turned it around and have started using the other side.
If you touch up your tungsten before it gets all messed up it will last quite a long time. It does just as good as our $1000 dollar sharpener at the union hall and way better than using a sanding belt or a tiger paw on an angle grinder. Plus it's pretty darn quite. I've been using mine for a couple of years (not that much welding at home but I do sharpen my tungsten for work a lot of the time). Can't hardly go wrong for around $50-$60. Overall, I'm VERY happy with mine.
America is a Union.
Old 09-06-2011, 03:21 PM
skelley521's Avatar
Nice, Thanks Bob. Gonna pick one up this weekend.
Semper Fi
Old 09-06-2011, 03:31 PM
GBM GBM is offline
Bob, that link does not work for me... can you list the SKU numbers on what you are referring to ? I tried entering my own search but several things might qualify for what you were referring to... Thanks...
Or skelly ...can you point me in the right direction ?
Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.
WW2 era Miller TIG.
Old 09-06-2011, 03:37 PM
skelley521's Avatar
Here
Semper Fi
Old 09-06-2011, 08:37 PM
shovelon's Avatar
Are you talking about this?
I see the black blade cover. Is this what you remove?
GaryJohnson2016
Old 09-06-2011, 08:49 PM
skelley521's Avatar
Yeah, cover/guard, if it's in you way and small children don't have access to the switch.
Semper Fi
Old 09-06-2011, 09:04 PM
This cover.
America is a Union.
Old 09-06-2011, 09:05 PM
GBM GBM is offline
Thanks, looks very nice...
Might could make another cover with proper size and direction holes in it .... perhaps even clear so you could see the progress....
WW2 era Miller TIG.
Old 09-06-2011, 09:09 PM
zapster's Avatar
zapster zapster is offline
Moderator
Regular 'ol bench grinder on a pedstal base with the guard removed is what I use..
Stand behind it and use the top of the wheel..
Cordless drill works great as a spinner..
...zap!
I am not completely insane..
Some parts are missing
Old 09-06-2011, 09:22 PM
CEP's Avatar
CEP CEP is online now
...zap!
Like so?
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
Powermax 1250, CNC table.
PROFAX Welding Positioner.
JD2 model 3
Old 09-06-2011, 09:25 PM
zapster's Avatar
Moderator
Originally Posted by CEP View Post
Like so?
Sorta..
Lose the guard and stand behind it..
Sparks go away from you..
...zap!
Old 09-06-2011, 09:34 PM
CEP's Avatar
How do you get around OSHA with the guard removed? I've been nailed by OSHA for having the rest more than an 1/8-inch from the wheel!
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
JD2 model 3
Old 09-06-2011, 09:36 PM
Won't give near as nice a finish as the saw sharpener. Can't blunt the points very well with a grinder. Does work OK though.
America is a Union.
Old 09-06-2011, 09:39 PM
zapster's Avatar
Moderator
I never blunt a point.
...zap!
Old 09-06-2011, 09:40 PM
By CEP;
At home use. A lot better than holding a 4 1/2" grinder with one hand while sharpening your tungsten with the other. But then again, I've never seen an OSHA inspector in a boiler.
America is a Union.
