Carbon Arc Torch building question...
Hi -
I have a Lincoln AC/DC stick machine and would like to build a Carbon Arc Torch for heating metal - like in this instructional article: http://www.instructables.com/id/Make...volt-stick-we/ Question: is there anything else that I could use instead of the Carbon rods?! Not sure where to get those... my father had left me a bunch of Tig tungsten spikes (sorry, don't know the proper term) - could those be used instead?! I have purchased two el-cheapo soldering irons hoping to harvest the rods from them, but the cheapo ones look like they are just made of regular steel... so I don't think that would work. Plz help. THx, James |
Re: Carbon Arc Torch building question...
Carbide - Carbon rods are readily available and inexpensive.
Any welding supply would have carbons in stock. In case you're stranded on a deserted island, I'll mention that a dry-cell flashlight battery can be "gutted" for a short length of carbon. If none of that works, PM your address to me and I'll slip a few carbons in a tube and mail 'em to you. Anyway, the Post Office needs the work. Interesting project. Keep us posted. Good Luck |
I have some 1/2" x 18" carbons with an enriched graphite center to give them a more stable arc. Similar ones used to be used in those WWII giant searchlights, and one-of-these-days I intend to see if mine work in one; I actually have a friend who owns two! ![]() BTW, one problem with using tungsten rods is that they require an inert atmosphere to keep from being destroyed; carbon is much cheaper too. |
I use the arc gouging electrodes commonly available at lws, in my home made carbon arc torch.
Not really made for heating and brazing, but readily available and they work pretty well.
Miller a/c-d/c Thunderbolt XL Millermatic 180 Vintage- -South Bend 9in. lathe - South Bend 7in. shaper -Craftsman power hacksaw - FibreMetal 710 |
Is there supposedly a special carbon for the CAT? |
Is there supposedly a special carbon for the CAT? I gouged with drive-in movie projector carbons for years - until I outlasted what was supposed to be a lifetime supply of 'em. ![]() Oldiron2 - that's interesting. I wonder what they used for power way out there and way back when? Good Luck |
I need to get some pictures of one sometime, not just for my own records, but to post here too. BTW, Zap; I'd bet there's no ordinance about glaring lights "accidentally peeping in" the windows or busy yards of obnoxious, noisy neighbors..... Did anyone make hollow carbons for gouging, similar in shape (but not action) to the exothermic rods? FWIW, here's a source of carbons; the first place I tried 'offhand': . |
as for hollow carbons, that would be interesting.
But... air doesn't travel down the center (as far as I know) the hollow center follows a theory about controlling current flow and not developing a "needle point" while burning. I've tried ‘em but didn't notice any big difference in operation. Good Luck |
shorter and not copper clad.(compared to 1/4" Arcair electrodes from my lws). I don't know if the carbon is any different.
Ok, I'm not getting this concept.
They are using gouging rods to heat metal to bend??
Semper Fi Jesus may have been a Carpenter, but his dad was a Millwright " A grinder and a can of paint, will make a welder what he aint' " I've done so much, with so little, for so long, that now I can do anything with nothing! |
Regular gouging carbons work fine in carbon-arc torches on DC, but not on AC. With DC, the positive carbon wears faster than the negative, and some people use 1 size larger carbon on the + side to compensate. Carbons made for AC do exist, they have a core made from various oxides which stabilizes the arc- movie-projector carbons are this type, but the core mixture is optimized to provide pure white light.
John
A few welders A lot of hammers A whole lot of C-clamps |
I've used gouging rods a lot, mostly 1/4" - 3/8" for gouging welds out, both round and flat.
I just don't get how they are using them for heating steel, wouldn't a O/A torch work better. Especially that home made apparatus doesn't even look safe to boot.
Try it sometime, just connect a carbon to each lead. Good Luck Last edited by denrep; 09-09-2011 at 09:54 AM. |
Thanks, I will give it a try. On the contractors machine first tho.....lol.
is the carbon arc only useful fwhen it is from carbon to carbon? Could you use one carbon rod arcing to a workpiece that is grounded through regular ground clamp to get a more "torch like" effect or would it not be hot from carbon to metal vs carbon to carbon ?
miller syncrowave 250 hobart handler 140 home made 400 amp engine driven in progress... |
Papa
Lincoln Idealarc 250 (circa 1962) Lincoln Weldpak 155 w/Mig Kit Lincoln Squarewave TIG 175 |
It takes some care not to "puddle" the surface of the metal being heated. Good Luck |
#19
I have a carbon torch and I use gouging carbons. I have an original box of carbons that was for the torches and they are carbon covered.
I use my dc gouging carbons both on ac and dc. it works both ways. I have used them as a single carbon were the arc is directed to the metal like a country boy tig and I have used them in pairs where the ard is running from one to the other and you heat the metal from the heat generated from the arc. In a pinch I have taken a strip of copper or copper wire and wrapped the carbon and then stuck the wire into my electrode holder. I then am able to slide the carbon up and down the wrapped metal and I am able to use the carbon as a single carbon torch. I do this when in the field and need to heat a bolt where I can't get a torch or can't use open flames. If I don't have copper wire I will take an electode and wrap it around a screwdriver and then slide the carbon through it. Trying to wrap a steel electrode around a carbon will break the carbon. |
#20
great tips!
LWS should have carbons? I want to try the copper wrap in an electrode holder trick.. and I can definately see use this for bolts as you say..
#21
the uv from the carbon arc is a lot more intense than what you get from weld rod. great tanning machine. you can get blisters without a great deal of efort. so cover up good. yes,i hurt myself pretty good the first day with the new toy---some 40 years ago.
miller thunderbolt 250v lincoln square wave tig 175 pro lincoln idealarc mig sp250 everlast tig 210EXT everlast power plasma 50 chicago electric (hf) 130 tig/90 arc chicago electric 90 amp flux wire 3 sets oxy/acet |
#22
Carbon arc used to be included with the little 50a buzz boxes from Wards and Sears.
It worked far better than the welding use of the welder. I have one setting out in the garage. The carbon arc part was used by slipping the insulated handles onto the output leads.
Hobart T225 HF 151/2 Cap mod HF 131/2 Cap mod Miller Cricket XL Century Portable Mig O/A |
#23
See this thread - Rather condensed version of about all you would ever need to know about Twin Carbon Arc with links showing demos and info on how to build your own.
http://www.hobartwelders.com/weldtal...ad.php?t=42262 |
