Old 09-12-2011, 02:44 PM
DieselDon16's Avatar
DieselDon16 DieselDon16 is offline
Pickup Truck Flatbed?
I was curious if anyone had any pictures of Steel Flatbeds they built for there truck. I have a Customer that wants me to build a basic flatbed with a Headache rack. It looks fairly easy and simple just wondering if anyone had any pics I could refer to as I go along. Any Pictures or Advice would be greatly appreciated.
Thanks Don.
Miller Trailblazer 302.
Miller Xtreme 12V Suitcase.
Lincoln Weldanpower 225 AC/DC
Lincoln - SP135T.
Bottles And All That Good Stuff.
http://djweldfab.com/
"We have The Right To Protect The Life of A Unborn Child" - Ronald Reagan.
Old 09-12-2011, 09:15 PM
millerkiller85 millerkiller85 is offline
Re: Pickup Truck Flatbed?
google it and youll find hundreds
Old 09-12-2011, 10:24 PM
macvance macvance is offline
This is one of the first posts I ever stumbled over and how I came to lurk around here in the first place.
http://weldingweb.com/showthread.php?t=48152
Old 09-13-2011, 02:16 PM
Thanks Guys, So far I found out, really just build a deck with supports and place 1/8" Diamond Plate sheet metal over the deck and build a headboard. Doesnt look that difficult.
Lincoln - SP135T.
Old 09-13-2011, 07:10 PM
Old Doug Old Doug is offline
Some steel supplyer here sale 1/8 D T steel with 3inch edge bent down 8feet by3feet you get 2 and weld them to gether to make bed. I built my bed out of 3inch channeliron for out side frame 3 inch angle iron cross members 2 by4 steel runors And 2by6 toung and grove treated wood floor.Floor is 23 years old and still in good shape.It would take 3/8 steel floor to hold up like wood does and things ride with out tieing down.Make sure tire have clearence when loaded.
Old 09-13-2011, 09:31 PM
boatbuoy boatbuoy is offline
i think i posted this here a long time ago.a friend had his pickup impounded and was told it had to be re-titled as a stake-bed to be legal. granted,he had mouthed off a wee bit and got the officer pissed. but still worth checking into in your state or area.
miller thunderbolt 250v
lincoln square wave tig 175 pro
lincoln idealarc mig sp250
everlast tig 210EXT
everlast power plasma 50
chicago electric (hf) 130 tig/90 arc
chicago electric 90 amp flux wire
3 sets oxy/acet
Old 09-13-2011, 10:41 PM
kolot's Avatar
kolot kolot is offline
This one is in aluminum but same idea.
"Si Vis Pacem Para Bellum"
(2)Lincoln 225AC/DC portables, Miller Syncrowave 300, miller sidekick,Lincoln Idealarc 250,Miller 251 Mig, Miller 30A spool gun, Hende lathe, Horizontal bandsaw, pora band ,14FT enclosed trailer.SA200's
Old 09-13-2011, 10:47 PM
kolot's Avatar
Main frame was 5 inch channel runners, crossmembes were 3 inch., headache rack is a 3x3x1/4 angle with 1 1/2 flat stock welded in on and angle to protect the glass. Deck is and .177 6061 aluminum diamond plate. Border of bed is done with angle.
Old 09-14-2011, 04:09 PM
Thats a real nice rig, I love those body style Fords. Thanks for your pictures, they really give me a Idea where to get started. Is it alright if I Consult you if I need advice on this project?
Thanks Don.
Lincoln - SP135T.
Old 09-14-2011, 05:26 PM
kolot's Avatar
That is exactly why we all tune in here, hope I can help.
Old 09-14-2011, 09:29 PM
Bob's Avatar
Bob Bob is offline
Here is one I built for a customer. He is 84 years old and is a rancher. The door for the goose neck can be opened from the ground and the lights connection fold out to hook them up from the ground as well.
Old 09-15-2011, 09:02 PM
kolot's Avatar
Here's one in steel, a dump with that will have wooden removable sides with the dump tail gate. good picture of a rub rail, The frame was made from channel, 2 main ladders then crossmembers, I used 10 Ga for the floor and it is 2 piece that seem up the middle. Each pan is bent with a return that forms the side of the flatbed that the rub rail is welded too.
Old 09-15-2011, 09:06 PM
kolot's Avatar
Left side of this picture shows how the floor of the bed is bent down and returns under the cross members in 1 piece, this was fast, strong, and gave a very neat appearance, wish I had a better picture of it.
Also note on this bed the cross members were butt welded to the main channels , it makes for more welding and more pieces have to be cut to length. Normally the cross members would just run over the top of the main channels but this being a dump with no subframe, I used larger main channels to take the stress ot the dump but had to reduce the overall height. Not to worry that skid steer boom has a manual safety lock, and the other end has temp.supports put in during welding.
