Old 09-15-2011, 06:36 AM
Rob Garner's Avatar
Rob Garner Rob Garner is offline
More homemade shop equipment.
It has been a while since I posted anything so here goes.
Welding positioner with a 1/2" x 12" platen.
It is basically a beefed up version of the Atlas® brand that is used at work.
The frame is 1" sq. 16 ga. wall along with 1/4" x 4" and 1/4" x 6" flat skinned with 20 gauge.
Darwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Old 09-15-2011, 06:39 AM
Rob Garner's Avatar
Re: More homemade shop equipment.
more.
Old 09-15-2011, 07:04 AM
Rob Garner's Avatar
Will add more details and pics after work.
Pics.
1) propane smelter
2) small roller
3) big roller
4) 12" disk 6"x48" belt sander
http://www.youtube.com/user/CARDAN531?feature=mhee#g/u
http://s159.photobucket.com/albums/t150/robg_010/
Old 09-15-2011, 07:10 AM
fronty_78 fronty_78 is offline
That is some beautiful workmanship! It must be great to watch your ideas take shape and be useful.
Old 09-15-2011, 08:37 AM
speedfreak87's Avatar
speedfreak87 speedfreak87 is offline
Forgive my ignorance, welding positioned? what is it?
www.thefusionsolution.com
Old 09-15-2011, 08:41 AM
papaharley03's Avatar
papaharley03 papaharley03 is offline
It's a lathe or turntable that slowly rotates the work piece for you. Some of them have a mig or tig torch mounted on them such that they become somewhat automatic.
Notice in the pics above how he has the ground lead attached below with a brush assembly riding against the shaft.
Lincoln Idealarc 250 (circa 1962)
Lincoln Weldpak 155 w/Mig Kit
Lincoln Squarewave TIG 175
Old 09-15-2011, 08:43 AM
ahhh.. I should have known that.. thank you.
Old 09-15-2011, 09:50 AM
CHINAMAN's Avatar
CHINAMAN CHINAMAN is offline
Where did you get those small gear reduction motor drives?
Thanks
Old 09-15-2011, 10:24 AM
forhire's Avatar
forhire forhire is online now
My question also... plus are these units variable speed or are you using some type of controller to regulate the speed? Those look like some handy little units.
Old 09-15-2011, 11:41 AM
aevald aevald is offline
Hello Rob, I have thoroughly enjoyed viewing your projects, the attention to detail and functionality, and the craftsmanship that you have displayed. Many could take note of and emulate your techniques to have success on their own projects, myself included. I will continue to look for additional projects that you are willing to share here. Great work! Best regards, Allan
aevald
Old 09-16-2011, 12:04 AM
Rob Garner's Avatar
Thanks
I found these at one of the local scrapyards but you can buy them from grainger and other places.
http://www.grainger.com/Grainger/DAY...ers&cm_vc=FFTS
Yes they are variable speed when wired to potentiometer. They are also reversible.
Thank you.
They are a motorized turntable. I use them primarily for round stock, sprockets, pulleys ...
http://atlaswelding.com/atlaswelding...FZJU7Aod5DHW8g
http://www.youtube.com/user/CARDAN53...23/lYF_0jzTp4E
Thank you for the kind words.
Old 09-16-2011, 12:52 AM
Rob Garner's Avatar
The furnace... this was the biggest sheet metal project I have taken on to date. Have always liked the look of the old riveted boilers so that is the style I went with. The shell is 15 1/2" Ř as well as tall and is made mostly of 20 gauge with a little 1/8 " thrown in.
Old 09-16-2011, 01:02 AM
Rob Garner's Avatar
more.
Old 09-16-2011, 01:28 AM
Rob Garner's Avatar
The slip roll:
Don't have many build pics for some reason. The frame is all 1/4" wall tube and the rolls (which are temporary) are 1 3/4" Ř. They were found at the scrap yard and are hardened about a 1/4" deep. The wheel is 1" square with 1/2" Ř spokes and is 48" Ř. The drive chain is #40 iirc. The jack is a 12 ton air/hydro from H.F. Pillow blocks are 1".
I am hoping to run across a good deal on either some 3"-5" solid round or tubing/pipe to make new rollers out of.
Old 09-16-2011, 01:31 AM
Rob Garner's Avatar
two more.
Will post more tomorrow night.
Old 09-16-2011, 06:27 AM
weldbead weldbead is offline
how did you turn the roller to roll the wheel that turns the roller?
Old 09-16-2011, 05:59 PM
Rob Garner's Avatar
Used a 12" crescent wrench. It turns really easy.
Old 09-17-2011, 06:16 AM
that pic is lighter than original post ..there it is! cool roller..
Old 09-17-2011, 07:38 AM
DSW DSW is online now
Moderator
Very nice. I'm book marking this for future reference.
A furnace is on my list for one day. It's been years since I did any sand casting alum. I've got any number of projects that could use that ability right now. I take it you just cast refractory cement in the shell you made for the furnace? Are you using one of the mig tip burners like they use for forges to heat it?
The positioner is another around to project at some point when funds allow. Right now I just make do with a small manual one I built to get by.
Very nice work. The attention to detail shows in things like the cover for the chain drive. I doubt many would have bothered, and it really helps show the time and thought that went into that project.
Ronald Reagan
Old 09-17-2011, 10:09 PM
acourtjester's Avatar
acourtjester acourtjester is offline
positioner parts
Hi
I have a ring gear and spur gear with a reducer setup attached. If anybody want to build a positioner PM me I will give you a very good price.
the ring gear is made to bolted at the center circle and the outer rotates being driven by the spur gear. They are pretty heavy 2-1/4" thick 88 teeth on the ring and 18 teeth on the spur. The ring is 16" diameter and spur is 3-1/2" Maybe 40 pounds total.
have fun
Tom
Old 09-18-2011, 12:50 PM
wintermute's Avatar
wintermute wintermute is offline
Rob,
On the positioner you built, do you think you'd be able to give us a good couple of close up pictures of how it's grounded to the central shaft? I could kinda see something that looked like a spring loaded copper rod in the pictures but not clearly enough to be sure. I'm thinking of building one of these and honestly, your design is what I'm gonna go off of
Thanks in advance.
--Wintermute
"No man's knowledge here can go beyond his experience." - John Locke
www.improvised-engineering.com
Manufacturer Agnostic:
Blood----------Sweat---------Tears
Lincoln Red, Miller Blue, Esab Yellow
Old 09-19-2011, 02:07 AM
Rob Garner's Avatar
Here you go.
Old 09-19-2011, 01:04 PM
wintermute's Avatar
Awsome Thanks Rob, I appreciate it.
--Wintermute
Old 09-20-2011, 03:20 PM
wed4life wed4life is offline
Re: positioner parts
Tom, I sent you a pm.
Thanks, David
Originally Posted by acourtjester View Post
Hi
have fun
Tom
Old 09-20-2011, 04:26 PM
Antibling Antibling is offline
Word of caution on your ground clamp setup, I don't know what kind of amps you'll be putting through that, but my positioner at work used to have that same style of setup. The spring lost it's tension and the weld started grounding through the postioners electrical and fried like 30 feet of wiring through the buzz bar.
They switched it to a type of clamp style, I'll try and get a picture of it for you.
