A Thread Thread
I needed to make an Acme thingy to use in a build of another thingy.
I don't have a jig for attaching round stock "ears" to bolts or other round things. So................................... ![]() I need the Acme threaded rod to be hinged. To make sure the axle/pin was true, I welded it to a piece of flat stock. Then used an annular cutter to cut a hole through the round stock, and flat stock, in a single pass. This left me with an absolutely true axle. Then I welded a piece of extruded tubing in the hole to accept the threaded bar. This is one piece completed. It will be the imobile part of the assembly There is another to do on the next post
Re: A Thread Thread
This next assembly is the nut assembly which will travel along the threaded rod as the rod is turned.
It's slightly different, but the same principle. The axle was welded to the piece of flat stock Then a section of the axle was cut out Then a hole big enough to allow the threaded rod to pass freely was cut through the stock And the nut welded on. The axles, although not touching the nut, will stay true. Welding in the gap would cause the assembly to bow due to the shrinkage Weird, but it works
Re: A Thread Thread
I suppose this has something to do w/ the "What the----????" thread. I take it you're not ready to enlighten us about that one.
Mike
Ol' Stonebreaker "Experience is the name everyone gives to their mistakes" Miller 175 mig Miller thunderbolt ac/dc stick Victor O/A setup Makita chop saw |
Re: A Thread Thread
Farmersamm- that`s Innovative Thinking in Action! Very Cool!
Rick V ![]() 3 CTC 70 amp Inverters in Parallel => 210 amps Stick! 1 Linde 250 AC/DC 1 Lincoln MIG PAK 15 1 Oxy-Acet |
Re: A Thread Thread
H,mmm I'm impressed, just not sure exactly why..............
Re: A Thread Thread
ha, I was just thinking when I seen the square frame flopped over so far on the lift thingy that your going to need a screw jack or something to adjust & hold the angle
miller 330a bp TIG miller dynasty 200DX TIG millermatic 185 MIG thermal dynamics cutmaster 101 plasma cutter snap-on YA5550 plasma cutter hypertherm powermax 30 plasma cutter baileigh CS225 cold saw etc.... |
Re: A Thread Thread
Decent source for Acme threaded products?
"Stick-man is wise" - Farmall "Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550 "StickyFingers-man" Commander 500D, LN25 Shopmaster 300, Super S-32P Hypertherm Pmax 600 Smith & Oxweld O/P |
Re: A Thread Thread
Re: A Thread Thread
I needed one to fix my (chineese) Bench Vise. I got the nut thru Mcmaster Carr. They were the only ones that i found that had M20 x 4.
Re: A Thread Thread
Samm, picture 4 shows nut welded, picture 5 nut not welded. Is there 2 of these or a change in plans? Bob
Re: A Thread Thread
I see there are 2. Bob
Re: A Thread Thread
Re: A Thread Thread
You might check these out as well as far as the Acme stuff there Stick-man.
http://www.use-enco.com/CGI/INLMPI?P...E=58&PMCTLG=01
Re: A Thread Thread
Fastenal stocks it locally in many areas.
Welders: Esab Migmaster 250 Penncraft 230 (oldy but goody) HF Plasma 30 (Italian) Lincoln Ranger 8 Smith Oxy/Acetylene/Propane Lincoln SA200 Everlast Power Tig 250 EX Everlast PowerUltra 205 |
Re: A Thread Thread
I make my own.
...zap!
Re: A Thread Thread
farmersamm has a mill but does he have a lathe?
can't wait to see the rest of the contraption
Re: A Thread Thread
Lincoln PowerTig 275 Miller 251 Miller DialArc 250 Bridgeport mill Hossfeld bender with dies Logan shaper Jet 14 X 40 lathe South Bend 9 model 'C'...sometimes a 'B' Hypertherm 900 Ellis 3000 band saw Too small a shop...too many tools |
Re: A Thread Thread
When you go fishing, you use the right bait. I'm hooked, now tell us what it's for!
Got to be something with a heavier load since you used acme thread. You're pulling something together with the pins I assume. Probably not pushing since that's a fairly long rod compared to it's thickness.
MM210, For sale $1k with cart,reg,gun,hose, and 250cf bottle Dynasty200DX w/coolmate1 MM Vintage Lincoln AC225 Victor O/A, Smith AW1A Cutmaster 81 IR 2475N7.5FP Rage3 Jancy USA101 9" SB 9" Craftsman/Atlas lathe (worn out) AEAD-200LE |
#19
Re: A Thread Thread
Very interesting.
We are on our way to being farmers! Our site is always under construction so check back often for updates. http://www.philosophyfarmstyle.com/
