Projects from a new guy
Hello, I'm new to this forum and after seeing some of the projects people have done,thought I'd post some pics of projects I've done. The pics aren't the best but hey I never planned on putting them on the net. Let me know what you think of the projects. I'm open to good and bad comments, that's how I learn to do things better in the future.
![]() The first 4 pics are what happens when I get bored with a Chevy engine laying around lol |
Re: Projects from a new guy
The next few pics are from the John Deere. I had to replace the plate for the snow blower and needed some weight over the back tire so this is what I came up with to fix the problems. The white plate in the last pic is where the plate goes on the snow blower.
These 4 pics are the bracket to add some weight over the back wheels, now the bracket is painted black. I have to get some new pics of it.
After checking out and wanting a lift table, but finding nothing in my price range that I liked I built this.... Made from 2x2x1/4 box tube and a air jack from northern tools.It has a 24 inch center table with 2 12 inch extensions that I can bolt to the sides to make it 48 inches wide and it is 8 foot long. I went cheap on the plywood top (man aluminum diamond plate got expensive
That must suck plowing snow backwards...
![]() ...zap!
And last, for now. I wanted a strong big picnic table. It's 12 feet long and 5 1/2 feet wide. Now everyone has a place to sit.
and the almost finished table. Next summer I'm going to have the Harley logo painted on the top then clear coated or maybe a bar top epoxy put on it. haven't decided yet.
that would make a hell of a race trophy.
There are no problems. There are only solutions. It's your duty to determine the right one. Hobart Handler 210 Airco 225 Amp MSM Stinger |
Hello Zap, Yeah I bet it would be crazy to try and plow with it, but it does drag and level stone nice. I have to try and plow this winter with and see how it works lol.
Hello Thor, Never thought about a trophy but, it would make a great derby trophy
On your first pictures of the crank, pistons, wrenches, and flywheel, it looks like if you had made sure all of the piston tops were fixed on a even plane, you could put some felt on them and added a glass top. Would make a killer shop table.
That's an idea I didn't think of. I kept thinking light fixture myself. Probably make an awsome chandelier for a man cave. Not sure if you'd want to do LED's under the pistons, ore do bulbs on the top of the domes. I do agree you'd need them all to be at the same angle however.
This could be shortened to"That must suck plowing snow". It wouldn't matter if it was forward, backwards or side ways. I don't even care to see it in a picture much less have to plow it. After you get it plowed, then what do you plant in the field? Anybody does any plowing around here they are planning on planting some kind of crop. Snow might not be so bad if it came during warmer weather, but then again everything is all a monochrome color of all white, everywhere.
...zap!
that's some nice projects. the parts and wrench creation would make an awesome table. not sure i would want to sit even remotely close to it as a chandelier though. hope those are cheap hf wrenches you welded in there.
225NT bobcat AEAD200LE Scott 125 mm175, mm252 w 30A, PT225 mm211, TA 181i Hyper Therm 380, cut master 52 9100X & XX, Digital Elite 6 Victor sets smith little torch, meco midget kalamazoo band saw steel max saw evoulution circular saw |
I was just posting about plans for a lift table, I like your, great job!! Its a touch different than the ones Ive seen in the catalogs, I wouldnt need one as big, great work!!
Hi guys, Thanks for all the comments. I think I'm going to make a table out of the engine wrench contraption. Never thought about it but I did weld it together upside down so all the pistons are even and they still pivot on the wrist pins so it would work as a table. With a piece of glass and some LED's in the bottom of the piston it would look great. Thanks for the idea!!
jbmprods your right all the wrenches are cheap ones that strip bolts instead of loosen them. Zap I have to agree with ya after 15 mins of plowing or snow blowing it does suck. The next thing I'm going to work on is a little cab for the tractor and maybe a little heater for it. |
ZAP you jinxed me lol.. Pulled out the snow blower the other day after the October snow
made it 20 feet and broke the drive chain for the auger. Being Sunday nothing was opened so I plowed backwards and it really SUCKS!!! but it worked to open the driveway. Well just got home with the new chain for the auger so off to the garage I go. Hopefully no more snow for a while.
