Cart for my miller roughneck 1e
Well was excited to get my welder running again and remembered the pain in the a$$ it was to move it around so I decided to make a cart for it. I grabed some scrap pieces from aroud the shop and this is what I came up with
Will Supports Autism AwarenessMy Toys BobCat 225 PLus Millermatic 130 Miller Spectrum 300 Cutmate Everlast Power Tig 185 Micro April is Autism Month . |
Re: Cart for my miller roughneck 1e
Need to find some material for some handles and maybe some cable holders.
Some handles and cable wraps will come in handy. I'd think about rerouting that exhaust so it's not blowing in your face when you adjust the machine. Looks like it will fit well between the engine and generator unit. Either that or point it straight up(if it's not left in the rain) or straight out the back. Those options will give you more room on the sides for the leads to go.
If you want to save even more headache, you might consider replacing that front leg with a free wheeling wheel (technical terms have never been my forte, but a wheel that can spin a free 360 degrees!)
Is that a 16 hp Kohler on that?
HH 187 Miller Bluestar1E |
I was looking at that today and found a smashed shopping cart with some casters that may work,
Looking good Will.
![]() You may want to consider moving the axle/tires a little closer to the center to take some weight off the panel end. That'll make it easier on the casters you're thinking of using off the grocery cart (buggy down here ). Especially if you plan on hanging the leads on there end as would be typical.Keep the photos coming.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Here it is with some handles I made for it.
Miller thunderbolt 250 Decastar 135E Recovering tool-o-holic ESAB OA I have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools. |
It has a bracket on the end by the tip. You can't see it in the picture but its there.
![]() If you look close you can see the bracket toward the end. Sorry the picture was a little blury.
Well been doing a little practicing here's some 7018 flat.
![]() And here is some vertical up that my friend told me I should try to master. ![]() OK fellas what am I doing wrong 7018 rod 1/8" welder settings rough 100-140 fine adjustment 50%.
