Old 12-11-2011, 09:13 PM
ryguy442 ryguy442 is offline
Sheilding gas flow problem
Hey guys I'm having an issue with my snap on mig welder. Im having a problem with it acting like its not getting sheilding gas. I just put a new regulator on it and that helped. But I got to turn the pressure way up to get it to weld right, this is making my tank run out pretty quick. Any ideas? Thanks
Ryan
Old 12-12-2011, 06:55 AM
welds4d welds4d is offline
Re: Sheilding gas flow problem
I assume that you've checked your entire system for leaks, even inside the machine (remember to unplug when you're in there!). Also, make sure that your nozzle is clean inside, and sealing to the gun properly.
Old 12-12-2011, 09:02 AM
Yeah iv checked all that I'll have to go back and go threw it again.
Old 12-15-2011, 12:26 PM
weldgault's Avatar
weldgault weldgault is offline
Check the holes in the gas diffuser. JG
SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFC
and Shielding Gases. There all here.
