Old 12-12-2011, 11:05 AM
Frosstyx Frosstyx is offline
Welding Electrode Selection
Hello all,
First to give you some background, I have been welding(SMAW) off and on for about 7 years and most of this was on a commercial job site doing various non-structural welding when needed. I also weld around the old man's farm (when he doesn't feel like doing it and I am able to visit) and have fabricated many various franken-parts for the tractor and other things around the farm and home but have solely used 7018 rods for most of the welding with decent(aesthetics wise) results. Also FWIW taking a welding class is on the bucket list, but right now I dont have the time.
I have a Lincoln 225 buzz box I keep at my place and am wanting to start some fabrication projects, I will be using mostly 3/16" a36 plate steel and some various 1/4" plate and tube a36. I'm sticking with SMAW because it is what I am comfortable with and I dont have $1k+ for a Mig that is capable of the same tasks. The first project I am going to tackle is a front end bumper replacement for my 2011 f150 4x4, then probably a rear end replacement. I am hoping to get some insight on what rods I should go for, I do not want to use an inferior electrode for the welds as this bumper will see some serious use but I just don't think the 7018 is giving me the results I need(aesthetics wise) as I want something that will require minimum grinding with a smooth bead as these welds will be exposed for painting and just be "easier" to deal with overall. As I understand it 1/8" 7014 may be the safe route to give me a good drag bead with decent penetration, is my thinking right or should I go with a weaker rod with less penetration such as 1/8" 6013 to get a better looking weld initially or would sacrificing the strength be a bad idea? Also would you recommend using a 1/8" rod over the 3/32" ?
I know its a winded question and I appreciate any help I can get, I just do not want to invest what little time I have for these projects in vein.
Old 12-12-2011, 11:16 AM
Bob the Welder Bob the Welder is offline
Re: Welding Electrode Selection
Maybe some 6011 but for the most part I would stick with 7018AC for that buzz box. With a little care and practice you should be able to get superior weld quality and aesthetics with the 7018AC. Better yet if you had a DC welder to use.
“There’s class warfare, all right, but it’s my class, the rich class, that’s making war, and we’re winning.” Warren Buffett
American by birth, Union by choice! Boilermakers # 60
America is a Union.
Old 12-12-2011, 12:54 PM
DSW DSW is offline
Moderator
7018 will probably give you the nicest look if you can run it. 7014 would be a close second. The key here is if you can run either well. If you can't run either of them, then chances are you won't get the results you want with any rod.
There's a bit more to this than simply pointing the rod at where you want metal. Prep, position, skill and settings will have a lot to do with your results. Have any one way wrong, and the rest really won't matter. Some picts of your welds and all the appropriate settings and info would help us give you suggestions as to what to work on.
Ronald Reagan
Old 12-12-2011, 01:00 PM
Katcracker Katcracker is offline
I have the little buzz box but its DC is yours DC? Mine will make as pretty of a bead as any machine out there on DC with some fresh 7018 and 6011 give the more stacked bead look if thats what you want. The 7014 will give a niiice bead on a bumper and be plenty strong. That is my 2cents. I would use out of a fresh can of 1/8 7018ac if thats all you got, its my favorite rod by far. I bought a rod oven just for the 7018.
Old 12-12-2011, 01:58 PM
Heavy Metal Service's Avatar
Heavy Metal Service Heavy Metal Service is offline
x2 7018 AC rod has inhanced flux helps arc start and metal flow makes it alot easyer with the old ac buzzers
Paul
Another day in paradise
You only have to be smarter than the metal". Weldini
Making an honest living is nothing more than stealing from someone who can afford it and everyone feels good when it's over . Weldini
Old 12-12-2011, 02:30 PM
The lincoln is the AC225S so its AC only, another concern with the 7018ac is having to "cook" em before I use them as this project will be done on the weekends so they will sit once opened for maybe weeks at a time and the wife would KILL me if I put welding rods in her over LOL, this and the fact that everything I have read says 7014 gives a better appearing bead, I can weld just fine with the 7018 but the bead is far from FLAT and I was hoping the 7014 would offer that advantage. I could very well be mistaken though, its happened before...
Old 12-12-2011, 02:38 PM
ironmangq ironmangq is offline
If you want a flatter bead either turn up the heat or move faster, If your pieces are beveled right and set up right you should be able to lay a flat bead in the groove with either rod. BTW 7014 tends to be an easier rod to run once you figure out your travel speeds and all, and 7018 does not "have" to be baked, for structural code work its required but many people have welded stuff with un-baked 7018 with no trouble at all, It will be more prone to hydrogen embrittlement and cracking but for a bumper I would not be worried
Old 12-12-2011, 03:41 PM
Just weld it hurry up
Lol oh ya pics please
Old 12-12-2011, 04:36 PM
Rick V's Avatar
Rick V Rick V is offline
Originally Posted by ironmangq View Post
...7014 tends to be an easier rod to run once you figure out your travel speeds and all, and 7018 does not "have" to be baked,...
I vote for 7014 !
On my arc welding course the last three months, both in class and at home I've been running almost the whole works: 6010, 6011, 6013, 7014 and 7018.
  • 7014 gives the smoothest beads - day in / day out. Run hot for super smooth.
  • Fresh from the Oven 7018 goes down nice... but taken home and stored, goes to crap in 2 days. I can tell because of the angry, spitting, snarling arc that wanders and is unstable.
  • 6013? Yeah... if you're perfect else slag holes or lines.
  • 6010/6011? Smooth bead? You gotta be kinding!
Rick V
3 CTC 70 amp Inverters in Parallel => 210 amps Stick!
1 Linde 250 AC/DC
1 Lincoln MIG PAK 15
1 Oxy-Acet
Old 12-12-2011, 09:01 PM
Silicon-based Silicon-based is offline
Another vote for 7018AC, even smoother than 7014 on an AC welder, IMHO. You can get them at Home Despot if you don't have a LWS nearby.
If moisture is a problem, just get an old, large toaster-oven, not hot enough for code work but good enough for down on the farm. After baking, store them in Rod Guards or vacuum-seal bags.
For best bead appearance, keep a steady pace and maintain a very short arc, almost dragging. Practice makes perfect! ;-)
John
A few welders
A lot of hammers
A whole lot of C-clamps
Old 12-12-2011, 09:22 PM
farmshop farmshop is offline
I really like 7014. 1/8" would be what I would use at about 130 amps or so. 7018ac works too but for me 7014 is my favorite. Don't like 6013 if I need a utility rod its 6011
Millermatic 252
millermatic 175
miller 300 Thunderbolt
lincoln ranger 250
smith torches
lots of bfh's
Old 12-12-2011, 09:49 PM
shortarc shortarc is offline
Another vote for 7018, crank er up and burn it in there, it will come out smooth.
Trailblazer 302
Hobart Stickmate AC/DC
Lincoln SP 135 T
Smith torch
Spoolmatic 30A
Old 12-13-2011, 12:32 AM
By Rick V;
I've got some Atom Arc 3/32" 7018 that's been opened and stored in a rod tube from Harbor Freight for a over a year and it will run just fine on my Maxstar for anything around the house, including a truck bumper. Wouldn't use it on any boiler tubes though.
For a root pass, not a cover pass.
America is a Union.
Old 12-13-2011, 01:24 AM
Rick V's Avatar
Originally Posted by Bob the Welder View Post
...I've got some Atom Arc 3/32" 7018 that's been opened and stored in a rod tube from Harbor Freight for a over a year and it will run just fine on my Maxstar for anything around the house, including a truck bumper...
That's good to know Bob because I've got a 9 lb box of the exact same ESAB product waiting to be opened... and my rod tubes with O-rings just came in!
I've also got an unopened box of the 1/8" Atom Arc 7018 also - same situation.
Thanks for the info!
Rick V
1 Linde 250 AC/DC
1 Oxy-Acet
Old 12-13-2011, 04:09 AM
Awelderiam's Avatar
Awelderiam Awelderiam is offline
Just a thought.....most all welding supply houses will stock the lo-hydrogen type rods in the 8lb cans, that way you only open one can. The rest are nice, fresh, and sealed waiting for your use. We used to use the 300lb ovens and store all of these rods that way, but now we just buy 200 or so lbs of rod in 8lb cans, what the welders dont use out of 8lbs they throw away. No more portable rod ovens and messing with the time the rods are out of the ovens ect.....nothing of your concern just an idea, dont have to buy a 50lb box. just my 2 cents...
A young green pipe welder asked an old salt one day...How can I make the weld on the bottom of the pipe look like the top.......The old salt replied....Screw up the top......
Old 12-13-2011, 10:33 AM
Stick-man Stick-man is offline
8lb cans? What brand and model? I usually only see 10lb or 50lb in cans, and 5lb, 10lb, 50lb in plastic or cardboard boxes.
"Stick-man is wise" - Farmall
"Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550
"StickyFingers-man"
Commander 500D, LN25
Shopmaster 300, Super S-32P
Hypertherm Pmax 600
Smith & Oxweld O/P
Old 12-13-2011, 03:39 PM
Awelderiam's Avatar
Lincoln..E7018...round tube cans, I would have swore they were 8lb, I bet they used to be, but now they are...10lb cans. I'll be, thats the second time I was wrong, I thought I was once but I was wrong.....
I only seen 1lb boxes....this is all Lincoln stuff....
Old 12-13-2011, 09:33 PM
Well I am thinking Im gonna go with 7014, gonna go out to the shop tomorrow and run some beads on some 1/8" coupons I made up today while completing my bumper mock-up ***WARNING the attached picture is the result of several MURDERED cardboard boxes...lol
I only mocked up one side as all measurements will be taken from the center-line and carried over to ensure symmetry... I am also going to have a prerunner style tube guard bent for it sometime in the future. Going to pick up a 4'x10' sheet of 3/16" a36 Friday morning and the cutting,grinding,and welding shall ensue... Thanks for all the help!
Old 12-13-2011, 09:51 PM
DSW DSW is offline
Moderator
Nice. At some point when I have spare funds I'd like to make one fairly similar to that for my 08 F550. Probably push the front out some more than what you show. I'll probably go out as far as the plow frame will let me go. Is that done over the existing bumper, or did you pull the stock one? Also I know on the 08's the air dam under the bumper is supposed to be fairly critical to fuel economy. The later model, taller air dam being the better unit. Any thoughts or plans on that with yours?
Do yourself a favor. Set everything up so you can weld it in the flat position if you want to make the welds as nice as possible. This may take some planning as the bumper gets heavier and more awkward. You might need to do some areas that would be the hardest 1st and then start doing the simpler joints as you start putting the whole thing together. The down side to this is it will be a bit harder than tacking everything up and then welding it all in position. You'll have to keep checking the fit to make sure you adjust if things start to pull on you.
Ronald Reagan
Old 12-13-2011, 09:55 PM
Put that much steel up front and you'll need some heavier springs.mock up looks good
Millermatic 252
millermatic 175
lincoln ranger 250
smith torches
lots of bfh's
Old 12-13-2011, 10:02 PM
I removed the bumper AND the trim piece above it before starting today and then put it back on lol...needless to say I will not be removing it again until I am ready to mount this one. I plan on starting with the sides where all those angles are, there are some nasty compound joints Im gonna get out of the way before I get into the larger front area. Also the tractor with a set of forks will aid me in keeping it flat, lol...
I was going to push this one out in the front but have no reason to as I cannot mount a hidden winch because the truck is the new EcoBoost engine and I cant block the intercooler that is in the center behind the bumper, I will bill cutting out a "grill" of sorts to allow for air flow. I have already removed the air dam or "valance" that give the truck the awful double chin look and from most of the guys that have done it and wrote about it they noticed no change in fuel economy, no added noise or anything for me...not driven it enough to gauge a difference in fuel economy but I doubt it will be affected.
Old 12-13-2011, 10:04 PM
I plan on it, well atleast better shocks anyway, the OEM bumper weighs a good 50-60lbs though, this will double, maybe triple that weight...
Old 12-13-2011, 11:21 PM
Just don't forget to post pictures of your progress. Looking good so far.
Trailblazer 302
Lincoln SP 135 T
Smith torch
Spoolmatic 30A
Old 12-14-2011, 07:05 AM
SuperArc's Avatar
SuperArc SuperArc is offline
With your AC-225 buzz box, I'd stick with 7018AC's. Never use 6013 unless you're gonna weld thin stuff like sheet metal. I think the 7018's are the nicest looking welds around. But, you'll get all kinds of opinions here.
Lincoln Power Mig 216 & 140C
Lincoln AC/DC-225/125
Miller 625 X-Treme Plasma
Milwaukee
Hilti
Dayton
Delta
Makita
Victor
Ingersoll-Rand
Baileigh
Old 12-14-2011, 09:15 AM
monkers monkers is offline
Nice bumper design! Take lots if pictures during the fabrication process please....I got a jeep jk that id like to make some bumpers for this spring
