Old 01-11-2004, 07:33 PM
cbrxx cbrxx is offline
Rebar question
I was cutting some rebar the other day and it smelled kinda funny, not like normal steel it had its own scent. Anyways I want to know if rebar is coated with chemicals, or is it just mild steel?
Old 01-11-2004, 11:03 PM
Scott S
Guest
Posts: n/a
It is made up of differnet alloys than mild steel. It is more brittle and should not be used for anything structural.
Old 01-11-2004, 11:05 PM
Dave Haak's Avatar
Dave Haak Dave Haak is offline
It's pretty common to use epoxy coatings on rebar in my part of the country. Keeps the salt from getting to the steel, if it should get into the concrete through cracks. Here light green is commonly used. You probably would have mentioned a paint like coating though. Anyway when heated/burned it gives off a terrible, very distinctive odor.
"Some days you're the dog, some days you're the fire hydrant"
Old 01-12-2004, 01:45 AM
vipermanz's Avatar
vipermanz vipermanz is offline
most of it i've used has been dark gray or brown, some are oil coated to prevent minor shipping rust
Stangnet
Shop Full Of Stuff.
Joey
Old 01-12-2004, 09:31 PM
Maybe it was oil, some of the rebar was dark grey, but most of it was rusted.
