Old 10-11-2006, 09:51 AM
alanaker alanaker is offline
Mercury Outboard racing part
Just finished water cooling this filler block. Can't see all the work, but I milled trenches down the sides, added cross holes, made cover plates & pipe fitting ports, then welded it all up leak tight. This filler block connects the 2 stroke exhaust ports to the exhaust megaphones. Supposed to add a few H.P.to the 44 cube motor. Now I know why more people don't do this... took a couple solid days of work. Now I'm scrambling to get the motor together for October 21/22 racing.
Old 10-12-2006, 03:55 AM
wello's Avatar
wello wello is offline
Moderator
Re: Mercury Outboard racing part
great job alanaker lots of work hope it makes those extra HP's for ya
good luck at the races keep uss posted how you went
Creative metal
A married man should forget his mistakes. There's no use in two people remembering the same thing!
