Tubing Bender
I am building this tubing bender:
![]() and I was wondering about what order I should go about putting it together. I do not have a welding table to tack things to, and it definitely needs to be plumb and square. Material is 2x2" 1/4" wall. Thanks, Mike
Building a Jeep from the ground up as a graduation present for my kid. Build thread can be read at http://www.jeepforum.com/forum/showthread.php?t=259306 Mike |
Re: Tubing Bender
Fabrication order is cut, drill, weld. For the tube bender pictured I would start with the base, then the two vertical pieces and then the bracing.
Re: Tubing Bender
I agree with the order above but I would weld the little U-brace to the diagonals before welding the diagonals in.
It's a minor thing, but distortion in the diagonal could pull the upright out of plum and since it's the last part, that is where you are going to have your last chance to make everything straight. |
Re: Tubing Bender
how exactly does that work? ive seen hydrulic tube benders,but never something of that design?
Re: Tubing Bender
Here is a photo:
![]() Basically it bends vertically instead of horizontally.
Re: Tubing Bender
That looks pretty slick, do you have a link to any more info on it?
Not that I need a tubing bender, but you know how it is when you see a cool tool ![]() Ok never mind I figured it out from the pic: http://gottrikes.com/ - John Last edited by runchman; 11-21-2006 at 01:11 PM. |
Re: Tubing Bender
Im building the exact same bender. I'm just waiting for the uprights to get back from milling then I'll be set to finish it. I was able to do all the other holes on my drill press though. I'm also using one of the air hydraulic rams instead of the manual one.
Should be pretty cool when its done. |
Re: Tubing Bender
We'll see a motorcycle frame emerge out of both of you guys that are making these benders, right?
Re: Tubing Bender
What is the cost for the dies for this?
Re: Tubing Bender
Re: Tubing Bender
Re: Tubing Bender
Wannabe, this guy has decent prices for dies: www.xtremecrawlers.com |
Re: Tubing Bender
A really stupid question (I've never been a tube-bender) - when you have a bend that is in more than one plane, do you just eyeball it or do you make some type of jig to calibrate it?
Say you are making motorcycle handlebars, for instance.... |
Re: Tubing Bender
Just get a couple of the magnetic angle finders and use those.
Re: Tubing Bender
Re: Tubing Bender
Tack weld a temporary brace across the top of the verticals and across the tips of the legs on the floor before welding.
Re: Tubing Bender
Please explain, Mike
Re: Tubing Bender
Not bracing it while you are bending.
Patrick |
#19
Re: Tubing Bender
Where do you get the hydraulics from??
#20
Re: Tubing Bender
Re: Tubing Bender
Yup,
The plans call for a 3-ton manual jack, but I went with the 8-ton air over hydro jack. That way all I have to do is hook it up to the compressor and pull the trigger and watch it go.
#22
Re: Tubing Bender
If it happens you can duplicate the red heat on the underside of the cross tube, the uprights will shrink apart. These kind of shrinkage problems arise even if the tube is six by six and half inch thick. ( I've been there !) Another way as mentioned is to tack weld it down to a one inch plate table before welding but the disadvantage with that is you cannot turn the thing over to weld on the flat which produces a superior weld...... Unless you are a "superior " welder :'))) |
#23
Re: Tubing Bender
I agree with everyone else, start welding the base/frame first.
You mentioned that a 8-ton jack was used. Is that the air/hydro from Harbor Freight? I am planning on building this bender, and was wondering how this jack was doing. |
#24
Re: Tubing Bender
Mike
#25
Re: Tubing Bender
That is a cool bender ! I wish I would have dont that with mine ! Also if you want to spend a few extra buck. Get a digital level. I swear by mine, Have used the others plenty but really love the digital.
Dan. Repair Specialties LLC |
