Goes to show, you can get a bad one of anything
Brand new, right out of the box. |
Re: Goes to show, you can get a bad one of anything
gotta resize the pic, all i see if your fingers and a 1/4 of the bearing.
ESAB MigMaster 275 Miller Econotwin HF Miller Syncrowave 250 |
I see pitted rollers, NFG
If they kept one roller out of each bearing they could make an extra bearing pretty cheaply. Mac
Thats where you put the extra grease.
CERTIFICATIONS: 7018M- H.V.O 10718M- H.V.O 11018M- H.V.O 9N10- H.V.O 71T-1-HYM- H.O.V 100S1 PULSE ARC 0,035- H.O.V 100S1 PULSE ARC 0.045- H.O.V ER70S-3 PULSE ARC 0.035 H.O.V ER70S-3 PULSE ARC 0.045 H.O.V ER5554- H.O.V |
Thats a muffler bearing, the exhaust gas excapes there.
wow napa too!!!
Esab Migmaster 250 Esab Caddy160I Hobart Ironman 230 Hypertherm Powermax 600 Lincoln Precision Tig 225 Lincoln IdealArc 250 Lincoln Weldenpower 225 Victor jr Oxy/Acetylene |
I work for a major bearing manufacturer that is a competitor to SKF...... I won't bash SKF, partly because I have no loyalty to my company, and because this happens at every manufacturer. Has nothing to do with Napa since Napa doesn't do quality inspections at the same level as SKF is supposed to. It happens...more than it should. its one of the more common bearing defects I hear about from my customers. I'd guesstimate it happens maybe once in a few hundred thousand parts...but we hear about it for sure. Take it back to Napa, they'll get you a new one.
also, i recommend a manicure haha
hahaha
Lincoln Power Arc 4000 Thermal Arc Fabricator 252 i Thermal Arc 26 tig Tweeko 200 amp spool gun Hobart AirForce 400 Miller Suite Case Xtreme 12vs WP-17V-12R |
george castanzas got nothing on your hand modeling abilities
i have seen quite a few oil filters with NO internal thread cut into them. Now thats QC!
HTP Invertig 201 Lincoln Idealarc SP250 Miller 180 AC Stick By farmall: They should have held the seagull closer to the work, squeezing evenly for best deposition. |
the picture on the box is wrong also.
![]() ![]() ![]() I've gotten brake shoes that were used in a brand new box before. |
I was talking about my hands not the bearing
I always tell everyone there is not a brand or manufacturer or part that I havent gotten a bad one right out of the box. They are all made by us humans afterall.
Put a carrier bearing in my friends kids truck and a few days later he comes in and the spot welds between the bracket and the bearing hanger all broke .
Out of six spot welds only two had penetrated enough to be called welds and they were the diameter of a pencil lead QC at it's finest I guess as long as the welds held to get out of the factory they were good
Backed my CATMA over your CARMA oops clusmy me ![]() What would SATAN do ?? ![]() Miller Digital Elite Miller Trail Blazer 302 Air Pak Suitecase 12RC Spectrum 625 Xtreme Victor O/A Evolution Rage 3 saw Rusty old Truck |
No problem, pull one roller out from the opposite side to even it out and it is good to go.
Give me a moment to get my bearings straight.
Rick V ![]() 3 CTC 70 amp Inverters in Parallel => 210 amps Stick! 1 Linde 250 AC/DC 1 Lincoln MIG PAK 15 1 Oxy-Acet |
#19
Napa is crappa, no doubt, but I don't expect chink QC from SKF...poop happens everywhere nowadays. First they
, then they Maybe you can squeeze them for a spare, too
![]() When a welder tells you to "stick it", what do they really mean? |
#20
Put one from the old bearing in there.
#21
The picture on the box is showing the bearing represented inside the bearing race! Its a taper roller bearing mated with its bearing race. Maybe your used to seeing the race inside of a tube or brake rotor, trailer hub??? The bearing race is usually already pressed into the part the bearing is going into. Maybe you thought the picture was that of a ball bearing like the 2nd pic? To me the picture on the box is correct based on the part in CarlH's hand.
Nickoli If I can't fix it, Its probably not broke.... Yeah Right! ~ Damn I let out the factory installed smoke again ! ~ Last edited by Nickoli; 01-17-2012 at 12:38 AM. |
#22
Bearston, your dragging knuckles are showing.
200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack. |
#23
It is the right photo
#24
that doesn't work .... not only is it a bad idea that will ruin a bearing, but it is also not possible on a taper bearing like this. the cage is formed around the rollers and the only way to get the rollers out is by cutting the cage. the rollers don't just pop out like they do in some needle bearings.
