Make it Good
I received as a gift, one of those Harbor Freight TIG inverters. I unpacked it and removed the cover to look it over. Well, it's not a Lincoln for sure, but I had some ideas on how to improve it and make it suitable for playing around with. The manual was disappointing, as it lacks anything informative about how its cycle works
so I guess you are on your own. I read on another thread about somebody adding a foot pedal on one of these inverters,so I am thinking it may be possible. http://www.weldingweb.com/showthread...ght=foot+pedalI have a pedal, salvaged from a Cebora (Italian) machine, that I think could be grafted onto this, with a few modifications (and some dumb luck) I will be posting some pics, and soliciting advice from y'all and try to make it good. Thanks in advance......Thttp://i15.tinypic.com/2ahbhv7.jpg |
Re: Make it Good
i hav'nt the foggiest idea of what you just typed..
but good luck with your adventure! ..zap!
Re: Make it Good
Drivesector Hobart Handler 140 Hobart Handler 180 Ready Welder 2 Hobart Air Force 400 Airco Stinger 225 Of all the things I've lost, I miss my mind the most."OZZY" |
Re: Make it Good
Electric shock can kill....man if that´s what hair dryers say......I think you get the point....
Just make sure you have someone that knows about electricity...
My Babies: HF Drill press HF Pipe Bender 3 4.5" Black and Decker angle grinders Lincoln Electric PROMIG 175 that´s it! |
Re: Make it Good
![]() Well I have a hot glue gun so that shouldn't be a problem.
Re: Make it Good
Then wire the contactor switch in the pedal to the gas solenoid, which I am not sure what kind of timer they have on there. I figure since it is scratch start, just use the foot contactor switch for a pre/post flow control. I wonder what kind of voltages run the gas solenoid? judging by the wire guage, not much.but the cooling fan is labeled 220v.I guess the next thing that I need to do is see about getting some 220v! Electrician in-laws will be here for Thanksgiving dinner, hmmmm........T
Re: Make it Good
I like how they paralleled so many little scr or triacs to make it able to handle the power as for the foot pedal you can just parallel another pot in there so when pot1 is say at x resistance and pot2 is at 0 or as close as it can some you will get full power then when pot2 increases the welding amperage decreases. If you want more info I can say more but right now it is 12:15 and I am going to bed just thought I would chime in real quick.
Re: Make it Good
heres another internal pic
Re: Make it Good
I had this same unit for a few weeks, and I played around with a second pot as a simulated foot control.
My idea was, use the pot on the panel for the 'max gas' control, and have the foot pedal pot go from 0 to max gas. I actually wired in a 2nd pot, then took it out and returned the whole unit to harbor freight. It's too late for me to recollect exactly what I did ('specially after a couple drinks) but if you want to PM me I'd be glad to work through it with you. I have an EE degree so if I can't figure it out I better be fired ! - John Oh yeah if you don't have any already, get some real tungstens, the ones that come with this are more like pencil leads. When I got some real ones, they barely resembled the HF ones. |
Re: Make it Good
I did notice the 'pencil lead' tungsten Will the standard weldcraft type collet bodies fit in this China torch? I have a 250 amp aircool layin around but it is much larger and I would have to rig up connections etc., but I have a box full of collets, tungsten, and stuff. I will rig it up if I cant get anything to fit the HF special. Thanks .....T
Re: Make it Good
You want tungstens and collets and what not for a #9 torch, should work fine.
- John |
Re: Make it Good
i think runchman had the right idea take the hole thing back add a few $$ and get a real TIG unit, even after messing with this POS to get a foot controle working if you can you will just have a POS with a foot control that you spent way too much time for the quality of weld you are likely to recieve.
summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you. ![]() feel free to shoot me a PM or e-mail me at [email]james@newyorkmetalart.com i got lots of time.
Re: Make it Good
On the other hand, if you can swing the money, you'll probably end up doing it eventually anyway ! - John |
Re: Make it Good
TIG being one of the harder welds to lern i think a crapy unit would just tend to frustrait you and put you off ever lerning it, where with a good unit you will have a beter chance of picking it up.
Re: Make it Good
Re: Make it Good
Re: Make it Good
if you already know how to TIG weld then you should be ok, even better if its an exersize to keep you buisy. i spent 4 days making a child cart to pull behind my bike, because i had no $$ to buy a new one partly and partly to give me some thing to do. all in all it came out great i think but to try to make them for sale would be insane with the time the wife and i have into it, but its the only one out there like it.
![]() i hope it works out for ya. i can certinaly understand 1/2 the funs in doing, and doing what you can with what you have.
Re: Make it Good
After discussing the subject, on this board and else where, I am now leaning toward abandoning this project and returning this welder to HF. My biggest concern is not having enough output power for the times that it is needed. I can't recall ever using a 1/16 stick electrode, and really have only seen them at HF. Another thing that kinda bothered me is how is it a 130A tig ,but only a 70A arc welder? there is no process switch, so how does the machine know what u have hooked up to it?
Another thing is, I really like welding on aluminum, so AC welding is kinda needed! So the search goes on, and I guess its O/A or nothing. Thanks to all who offered their .02. "You can't park that here." "I'm not parking it, I'm abandoning it."
Re: Make it Good
my TA is the same way 185 TIG and only 150 stick, but i have to tell it wich ine i am using.
![]() sorry to here you abandend the project, but hope you find a TIG unit to play with soon its a lot of fun and verry relaxing.
#20
Re: Make it Good
There´s a guy here that made a nice TIG pedal for the same machine. If you want to have AC you´ll go with some BIG $$:..but at the end it will be well worth...
Might wanna check out the link, seems the pedal works just fine.
#21
Re: Make it Good
- John |
#22
Re: Make it Good
I can't wait until it arrives Ebay was my friend in this deal, as all 4 items came from different vendors. I will post some pics later of the fine welds it makes.
Re: Make it Good
A dragster 85 ?
John - fabricator extraordinaire, car nut! - bleeding Miller blue! ![]() http://www.weldfabzone.com
#24
Re: Make it Good
congrats, i hope all goes well from here.
#25
Re: Make it Good
Looks like alot of research went into this pedal project. I can tell someone knows there@#$%!
I lack in the electronics department. I am impressed with your knowledge, which comes to my question I have a Thermal arc 185 AC/DC inverter tig welder. They want close to $300 for a foot pedal.Not gonna do it! I'm not sure if I made a mistake buying a Lotus foot pedal off of Ebay for $69+ shipping . It seems to be of a pretty good qaulity for the price. The pins dont match up but I got in touch with Tyco electronics and found a matching male plug that will fit the welder, #206434-1. The pedal that I purchased has a 5 OHM pot that has 3 wires conected to it(red-yellow-green). Has a on/off pedal switch with 2 wires Black and Brown. TA185 AC/DC tig welder diagram: Pin# 1........chasis ground Pin# 2.......contactor control/+24VDC Pin# 3.......contactor control/GND Pin# 4.......not used Pin# 5.......potentiometer maximum Pin# 6.......potentiometer minimum(GRN) Pin# 7.......amperage control wiper 0-10 VDC Pin# 8.......not used Can this pedal be wired in to fit this welder from the info I provided? If need be I can put up more info from the diagram schematic. Any help would be greatly appreciated! |
