#101
Old 02-12-2012, 10:44 PM
Pavinsteelman Pavinsteelman is offline
Re: Is there any value to this lathe?
Hi if with a tool in your tool post you can center it up to the center of the lathe you can use it the way it is. See. it runs fine , time for paint. John
Old 02-23-2012, 08:59 AM
wb4rt's Avatar
wb4rt wb4rt is online now
Just to keep you up to date with this project.
1. I have wired a switch on the front to eliminate reaching over the lathe.
2. I added a lamp since I'm old and need extra light.
3. Roy sent me some oilers, oil, and bits. See the new oilers!
4. I ordered and pressed in the handle on the cross-slide hand wheel since it was missing.
5. I made a rocker wedge and plan to oil temper it this week-end.
6. I have actually "turned", sort of, a piece just to see if it runs true, and it does!
7. I am bidding on some toolholders (3/8" x 3/4") or may order from Grizzly.
I am hoping to clean and paint it when I have time.
This project has been a lot of fun and I really appreciate all the comments y'all have posted. Please continue posting and I will update as I make progress. This lathe is already able to do more than I know how to do, so to answer the original question I asked, "Yes! there is a lot of value to this lathe".
You can see it running on the youtube link above. http://youtu.be/tSEvL4ophi0
Burt
_____________________
Miller Syncrowave 250
Millermatic 211 w/Spoolmate
Miller 375 Plasma Cutter - terrific machine
Miller Thunderbolt XL AC/DC
10FtDrillBit.com
Old 02-24-2012, 09:45 AM
Hi try the place CDCCO post # 66 they have what you need also ENCO . Looks good , John
Old 03-04-2012, 05:44 PM
wb4rt's Avatar
I primed and painted the lathe. I bought some toolholders. Can't wait to try them!
I'm not clear on how the boring attachment connects because it wont fit my post. But it came with the right size toolholders.
I need to find some scrap pieces to practice on.
Burt
10FtDrillBit.com
Old 03-04-2012, 05:59 PM
WyoRoy WyoRoy is offline
Post up a picture of your boring attachment Burt. Maybe we can help you out or figure a work-around.
Lincoln PowerTig 275
Miller 251
Miller DialArc 250
Bridgeport mill
Hossfeld bender with dies
Logan shaper
Jet 14 X 40 lathe
South Bend 9 model 'C'...sometimes a 'B'
Hypertherm 900
Ellis 3000 band saw
Too small a shop...too many tools
Old 03-04-2012, 06:15 PM
zapster's Avatar
zapster zapster is offline
Moderator
You have done a bang up job on that and should be commended!!
In it's ORIGINAL state I am willing to bet that is a item that Mike and Frank from "American Pickers" would want it..
...zap!
I am not completely insane..
Some parts are missing
Old 03-04-2012, 06:59 PM
brucer's Avatar
brucer brucer is offline
some of the old style automatic oilers on the spindle bearings would be a nice upgrade..
Its good to see You found value in that old lathe
www.necessityjigs.com
Old 03-04-2012, 07:32 PM
zapster's Avatar
Moderator
Holy crap!!
I just noticed that it is a hand feed carrage!!!
WoW!!
Lets see you thread with that!!!
Awesome!!
...zap!
Old 03-04-2012, 08:48 PM
brucer's Avatar
It wouldnt be to difficult to add anti-backlash nuts and stepper motors to it..
Old 03-05-2012, 08:45 AM
wb4rt's Avatar
Hey guys,
Thanks for the feedback.
Zap - since I don't know how to thread, yet, it is not a problem. But I'm working on it.
Roy - I will post a picture of the boring tool, but it is in Grizzly's 20 piece lathe kit: http://www.grizzly.com/products/Lath...t-20-pc-/H5868 The toolholders fit perfectly, so you would think it is sized for this lathe but is is about 5/8" or so square and will not fit in my post.
I managed to turn a little steel, break a little, throw a bit, sling the cutoff end of what I was turning! Man this is like being back in the Army. I guess I need to read some more in the book.
Here is a picture of the lathe after I painted it this week-end.
Burt
10FtDrillBit.com
Old 03-05-2012, 10:58 AM
Burt, As far as that boring bar goes, you may have to do a bit of modifying to make it work with what you have. If the round shank of the bar can be seperated from the square mount, or you can turn the square mount down on your lathe, the simplest method may be to measure to center height and drill out a piece of stock, drill and tap for a set screw and mount on your cross slide similar to the photo below. See what you can come up with in order not to have to mess with removing that square mount.
Miller 251
Miller DialArc 250
Bridgeport mill
Logan shaper
Jet 14 X 40 lathe
Hypertherm 900
Ellis 3000 band saw
Old 03-06-2012, 01:52 PM
lamename's Avatar
lamename lamename is offline
Nice job. I watched the video, I think you bored the hole too deep, that or you have some serious lung capacity.
Cool project!
Hammer
File
Big Hammer
Here, let me Google that for you...
Old 03-27-2012, 01:01 PM
wb4rt's Avatar
Hey Guys.
I really appreciate all the advice and help I have received on this project. Now I have some more questions. Please remember I am starting at the bottom as I have no training nor experience on using a metal lathe.
I'm trying to use the lathe to redrill 1/4" to 9/32" in tool steel. I have tried 3-4 brand new bits and still have not been successful. It will start drilling, but very quickly becomes too hot. In fact I have had both the piece and the bit glowing cherry red. I have used tapping fluid but it just burns. The piece turns dark. It is like the bit is not cutting, it is just putting pressure on the piece. It does enlarge the hole, but not as deep as I need. I have tried slowing down the lathe. I have the tailstock lined up. A 1/4" bit fits all the way. Then I change the bit to the 9/32" and nothing works as I expect.
So maybe someone just start with the basics.
What rpm should I be running (and any advice on how to determine other than mathematically)?
Should I use a mill end instead of a bit since it is tool steel?
Any particular coolant?
Or ?
Thanks in advance.
Burt
10FtDrillBit.com
Old 03-27-2012, 01:50 PM
lotechman lotechman is offline
If you are cutting tool steel your lathe might not go slow enough. 4 times the Cutting speed divided by the diameter in inches is a quick formular for drills and turning.
With high speed steel 100 feet per minute is max on mild steel.
With high speed steel cutting tool steel you need to get below 50 fpm
4 X 50 / .250 = 800 rpm maximum ... slower if you can.
Soluble cutting oil is good for drilling but if you don't have any oil will cool and lubricate the cutting action. If your chips are turning blue you are turning too fast.
If you are trying to drill hardened tool steel then it might be as hard as the drill bit. You can get an idea of how hard it is by running a file over the surface. If the file skates over then it is as hard as the file and you are not going to have much luck with regular drill bits.
Old 03-27-2012, 02:16 PM
forhire's Avatar
forhire forhire is offline
It sounds like the part is hardened. Have you tried annealing it?
You may need to hard turn it. Do you have a single point tool small enough? A micro carbide boring bar like one from micro100 http://www.micro100.com/ would be ideal. I think Accupro makes some less expensive versions. If your careful the tools will last a long time and can be sharpened using a diamond hone.
Old 03-27-2012, 02:27 PM
brucer's Avatar
are you using cobalt drills?
ditch the high speed drills and go to cobalt.. a little trick, try using regular coca-cola for coolant..
try about 200-250rpm.. about 2ipm feed
Old 03-31-2012, 03:35 PM
Solid carbide bits and use water to cool , it maybe too hard to drill , ceramic and diamond tooling is common in cnc work .
HTML code is On
