Old 12-12-2006, 06:35 PM
flamephil flamephil is offline
what's the best way of bending this!!
hey!!
got a project that i'm not sure what's the way of doing it!
bending a large radius out of 1.5" pipe on 20 foot long, take a look at the picture and feel free to give your opinion on you would do it!
thanks
Old 12-12-2006, 07:26 PM
littlefuzz's Avatar
Re: what's the best way of bending this!!
not sure but I want one. might be easier to use some 1/4 flatbar for the bent pieces and weld in struts.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 12-12-2006, 07:39 PM
chopper5 chopper5 is offline
is it some kind of snow board grind rail
Chuck
ASME Pressure Vessel welder
Old 12-12-2006, 07:43 PM
yes it's a snowboard rail that i have to make for the local ski hill.
don't have acces to a roll forming machine and would like to make it myself, also want to be nice without kink!
Old 12-12-2006, 07:46 PM
what kind of equipment do you have ?
Chuck
Old 12-12-2006, 08:03 PM
lorenzo's Avatar
lorenzo lorenzo is offline
Would you be buying the stock from a steel supplier? Sometimes the steel suppliers have forming services..... you just need to know the rudius of each rail.
Old 12-12-2006, 08:05 PM
littlefuzz's Avatar
If ya don't have a good way to bend the pipe, I think 1/4 x 3 flatbar would be sufficient and a lot easier to shape. Put struts in as you go and put your UHMW on top. Pipe would definatly look better though.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 12-12-2006, 08:08 PM
almost anythiong a small shop has: welder, torch ....lathe , milling but no roll bender!! this 20 feet long with matching radius(approx25 feet radius)!
Old 12-12-2006, 08:10 PM
absolutely need pipe as snowborder slide on them , there .250"higher than the plastic!!
Old 12-12-2006, 08:18 PM
lorenzo's Avatar
You wouldn't want to to use flat bar because the edge of the bar could damage the underside of the board. Plus the radius would be different from pipe to pipe, the outside pipe would have a larger radius. If you had a 25' radius for the centerline of the outside rail and the inside rail was set 12" from the ouside rail you would use a 24' radius for the inside rail.
Old 12-12-2006, 08:31 PM
well you could heat one side of the pipe with your torch make a red hot stripe and let it cool and that will put a curve in it but thats going to use a lot of gas
you'll need to draw an arc on the floor or make a wood template to make them same
Chuck
Old 12-12-2006, 08:49 PM
sorry, didn't put enough details.
25 fett outside radius with matching radius at 16" between pipe.
20 feet long 1.5 sch 40 pipe!
heating could be a good one but as you said, need alot of gas!
mabye multiple small bend at equal distance!
Old 12-12-2006, 09:10 PM
zapster's Avatar
zapster zapster is offline
Moderator
your in really deep here..
how did the first project turn out that you posted?
one at a time...
...zap!
I am not completely insane..
Some parts are missing
Old 12-12-2006, 09:15 PM
finally went good!!
Old 12-12-2006, 09:30 PM
trying to send pics but too big and too dumb to know how to resize!!
Old 12-12-2006, 10:13 PM
pics of other rails i did
Old 12-12-2006, 10:16 PM
WHughes's Avatar
WHughes WHughes is offline
I am also too dumb,
Sign up at photobucket.com and upload them and then click edit and resize them for whatever application you need.
Bill
Old 12-12-2006, 10:17 PM
pics rails structure
Old 12-12-2006, 10:20 PM
zapster's Avatar
Moderator
good job!
and you were worried about a little "twisting"..
...zap!
Old 12-12-2006, 10:23 PM
anyone tried bending tube by attaching both end with a ling and hand winch to radius(large like in the pics)???
Old 12-13-2006, 12:22 AM
Wetback Wetback is offline
Huge Jig. and a Torch.
Old 12-13-2006, 12:44 AM
TEK TEK is offline
If you have a steel table you can weld some pipe or round stock to it. Two pieces a couple of feet apart and a plate welded on the centerline of those where you can put a hydraulic jack. Place pipe against rounds. Put jack on plate. Push to a mark, little bites at a time.
Old 12-13-2006, 01:38 AM
littlefuzz's Avatar
I figured the board would be in contact with the uhmw instead of the pipe, sorry I'm an amateur snowboarder. I haven't got to the rails yet, I try to concentrate on staying up
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 12-13-2006, 02:01 AM
Weldingyota92 Weldingyota92 is offline
Where you at man we have two rollers at work and I plan on making one as well. we roll a lot of rail and tubing so making one of those shouldnt be to hard. Try finding a hand rail company near you thay all have rollers that can make that bened in like 10minutes flat man..
Old 12-13-2006, 02:02 AM
lotechman lotechman is offline
I think that winch idea on a 25 foot radius would work quite well. The ends are not going to bend as easily as the middle third. Make a wooden template/sweep and compare the inside as you pull. When the middle comes to the correct radius tack a brace on the inside then continue tensioning so that the outer ends bend to match.
