Old 12-17-2006, 05:10 PM
jonesiera
Guest
Posts: n/a
Miller VS Hobart
Is the Hobart 210 as good as the MM210? This is not for production but for use around the Barn.
And will the Miller 250 Gun fit the Hobart 210?
Thanks and I'm sure I'll get different views, and thats fine with me.I do thank you.
Old 12-19-2006, 02:24 PM
Visorblue's Avatar
Visorblue Visorblue is offline
Re: Miller VS Hobart
Hello. Have you called Miller to speak with an application engineer? They're sister companies so they should be able to address your questions. You can probably even email them if you want. Good luck!
Warning: I have been wrong before!
New small workshop, small MIG, oxyacetylene set with a DHC-2000 that I'm learning to use and really like. Life is good!
Typos are there for those that look for them. I try to do something for everybody.
