Old 02-02-2012, 05:30 PM
morgaj1's Avatar
morgaj1 morgaj1 is offline
My New Smoker
After collecting metal for a year, I finally got everything to make my 36" reverse-flow offset smoker. The main chamber is a 20"x36"x5/16" reclaimed natural gas pipe.
After sandblasting:
Firebox made of 1/4" plate:
All put together:
Heat Diffuser:
All that's left to do is cut out the firebox vent, final grind and paint.
Old 02-02-2012, 09:49 PM
DemonSpeeder's Avatar
DemonSpeeder DemonSpeeder is offline
Re: My New Smoker
Sweet, now fire that bitch up !!
Lincoln pro mig 180
Lincoln Square Wave Tig 300/wp 20/home built water cooler
Victor, Purox, Harris, O/A welding/cutting setups
Vintage Craftsman drill press
Vintage Craftsman/Atlas 12"x 36'' lathe
7''x 12'' w/c band saw
Everlast 140 st
Old 02-03-2012, 10:30 AM
Ryf Ryf is offline
Re: My New Smoker
that heavy gauge will be sweet at holding nice even temps, nicely done. if you have a garden tractor, I might recommend a removable tow bar, in case it ever needs moving off hard paved areas. I would assume that thing is heavy heavy hehe.
Hobart Handler 190
Century 90amp on Flux
Craftsman 200amp buzzbox
Old 02-03-2012, 10:41 AM
lawrence0485 lawrence0485 is offline
Re: My New Smoker
Very nice. I've been thinking of building on myself.
Old 02-03-2012, 12:22 PM
jrose jrose is offline
Re: My New Smoker
Looks good! One thought before you finish is a drain going from the heat diffusion plate through the bottom of the smoker. Helps with clean out.
Fire it up!
Roll Tide!
Old 02-04-2012, 05:44 PM
morgaj1's Avatar
Re: My New Smoker
I finished the smoker today. I got the propane starter welded in, added the air vents, burned it out and did the final grind. Here are some pictures of the first wood burn:
Next week, it will go to the shop for sandblasting and painting,
Old 02-04-2012, 10:08 PM
Asolis's Avatar
Asolis Asolis is online now
Re: My New Smoker
Awesome pit! The only things I would of change is the hinges on the fire box,I think they are abit too small. I can see that latch by the breathers getting really hot.
Old 02-08-2012, 02:09 PM
jfive jfive is offline
Re: My New Smoker
Making a smoker myself soon. Mines gonna be a warm smoker though. Have a BBQ smoker like this and I find the stuff has to be close to the hot side to get smoked and cooked properly.
Old 02-08-2012, 07:51 PM
MilitiaMetals MilitiaMetals is offline
Location: Saskatchewan, Canada, (right above North Dakota and Montana)
Re: My New Smoker
AWESOME, I love smoking meat! I have a smoke house, but am going to build a smoke grill like yours soon.
Old 02-08-2012, 09:25 PM
morgaj1's Avatar
Re: My New Smoker
This is a reverse flow design, so there really is not a hot side. On the first burn, I had temperature probes on either side of the cooking grate and there was on 15* difference.
Old 02-08-2012, 10:17 PM
Re: My New Smoker
I still don't get why they call it a reverse flow, its still flowing away from the fire so there is nothing really reverse about it. Or feel free to educate me lol, I dunno?!?!?
What temp are you guys smoke/cooking at? When I smoke my jerkey, bacon and hams, I go by an old butchers book and don't go over 160*F but that is with cured meats, I have not smoked anything yet that is not cured. I have a propane burner in the bottom of my smokehouse. I built it large enough to do a whole deer thats been quartered. It stands 6 feet tall, smoke box is 4 feet wide, 4 feet deep, and 5 feet tall.
Old 02-08-2012, 10:21 PM
TheJackal TheJackal is offline
Re: My New Smoker
I do about 190 for 8 hours
Team Fiscal Conservative Member #001
11' Ranger 250 GXT AC/DC
Hobart 180 mig
Thermal Dynamics Cutmaster 81
12' Lincoln Precision Tig 225
08' LN25
Old 02-08-2012, 10:42 PM
morgaj1's Avatar
Re: My New Smoker
It is reverse flow because the heat makes a 180* turn and reverses flow out of the diffuser and over the meat. It depends on what I am cooking as to my temp. Beef Brisket, chuck roast, pork ribs and butt, I usually cook at about 250*. Turkey and Chicken, I cook at 325*.
Old 02-09-2012, 05:46 AM
Drf255 Drf255 is offline
Re: My New Smoker
Great builds. Can you post up some plans and more pics?
How did you make the propane burner? Was it homemade or recycled?
I want to build one, but I'm a bit clueless about the design. Can one be made that would be able to use both a side firebox and also use logs/charcoal right under the grate for direct heat?
I'd like to make one I could smoke ribs or a whole suckling in, then be able to char up steaks.
TA300 ACDC
Miller Coolmate 3 with CK230 Flex
Hypertherm Powermax 45
TA161S
TA 95S (RIP-drowned in Sandy)
Miller XMT 304 CC/CV
Miller S22P12 Suitcase
Old 02-09-2012, 09:20 AM
Re: My New Smoker
I do fish and summer sausage at 180-190. I don't like smoked salmon like the stores where it looks like sushi. Also I use 100% alder when smoking fish results are great. Smoke alot of whole 1/2 lb kokanee and you want them cooked, unless your going to can them. I never use smoke when making jerky. I just use mine for the low heat and racks. I have this grill and was just saying using the firebox only, I had issues, thought you might too. http://www.google.com/products/catal...=0CO8BEOUNMAQ#
Old 02-09-2012, 05:13 PM
Re: My New Smoker
ah now I get the terminology
Old 02-09-2012, 06:48 PM
Re: My New Smoker
Mine use's a section of heavy wall 4'' pipe to create the "reverse flow", only one valve being used on the end of the stack, easily gets up to 250 deg or so, and temps seem to be consistant from end to end.
Lincoln pro mig 180
Everlast 140 st
Old 02-09-2012, 09:28 PM
morgaj1's Avatar
Re: My New Smoker
If you will PM me your email address, I will send you a Microsoft Excel file of the plans I made. The burner is an LP fireplace starter:
http://blueflamestore.com/plumbing/c...-straight.html
Here is the regulator I got for it. I got the model COM3:
http://www.tejassmokers.com/gasregulators.htm
I welded a 2"x1/2" black pipe nipple to the fire box. Then, I screwed the LP burner into the inside of the firebox and the regulator to the outside of the nipple. That way, if the burner goes out, I can replace it. Also, once the fire is going, I remove the propane tank so it doesn't get too hot and explode. Here are some more pics:
Here are some pics of the heat diverter. It is made of 1/4" plate steel. I welded a lip on the left end to catch grease so that it doesn't go into the fire:
Old 02-10-2012, 02:37 PM
morgaj1's Avatar
Re: My New Smoker
The build is finally done! I picked it up from the sandblasting/paint shop last night:
I got them to sandblast the cooking grate because it had a good bit of rust on it:
Old 02-10-2012, 03:12 PM
Re: My New Smoker
Looks good. What kinda wood is that?
Old 02-10-2012, 03:23 PM
morgaj1's Avatar
Re: My New Smoker
It's red oak. That is the most plentiful wood around here. Occasionally, I will run across some pecan or hickory, but mostly oak.
Old 02-10-2012, 03:45 PM
Re: My New Smoker
I had a steak that was grilled on a open oak grill, and it had some of the best flavor I have ever had.
Old 02-10-2012, 06:28 PM
morgaj1's Avatar
Re: My New Smoker
I like oak, but pecan is my favorite. If I ever get some hickory, I will mix it with oak because hickory can be overpowering.
Old 02-11-2012, 12:09 AM
Re: My New Smoker
I made the mistake of using all hickory on a batch of fish one time, and it was so strong you couldn't eat the stuff. Alder is my favorite, but I have never had access to pecan, so don't know how to compare. I took some red oak from my local hardwood dealer, as the wood often comes in on oak pallets, and he uses the red oak for firewood LOL. Will have to try it out this summer when I get mine done. For now I am stuck still using my little chief, and actually used it today to smoke salmon I caught yesturday.
Old 02-11-2012, 12:20 AM
Ryf Ryf is offline
Re: My New Smoker
looks awesome! one thing you might want to do to keep the paint from peeling, if you or anyone else wasn't aware, spray the outside down with PAM cooking oil to keep the heat from blistering the paint over time, a coat again before winter will help keep the rust at bay. great looking smoker.
Hobart Handler 190
