Old 01-05-2007, 08:41 PM
gmc1999 gmc1999 is offline
2024 aluminun
Ok, heres one this is for airlon's on a airplane wing, military spec. Is there a way to weld it even though it's non-weldable. I really don't want to go to prison because of a military airplane crash.
MILLER ELITE WELDING HELMET 29 ROADSTER
MM 251
Lincoln Precision Tig 225
Weldtech Cooler
Old 01-05-2007, 09:05 PM
lorenzo's Avatar
lorenzo lorenzo is offline
Re: 2024 aluminun
I thought the military only wanted aircraft repairs made with rivets...
_________________
Chris
Old 01-05-2007, 09:44 PM
riley mcmillan's Avatar
riley mcmillan riley mcmillan is offline
Re: 2024 aluminun
There are proceedures to follow in mil spec. I've seen people fired for something as simple as not following proceedures in alodine treatment of aluminum after it was stamped off on a workorder. These proceedures are there for a reason.
Old 01-05-2007, 10:27 PM
Doolittle Doolittle is offline
Re: 2024 aluminun
I welded some 2024 3/4" rod together for fun (got it from the ol' scrap yard). The welds held but were big fat things and brittle (too much silicon?). Anyway, I wouldnt risk it unless... you find an approved procedure somewhere. Probably need to use a specific rivet and patch material to be in spec I would guess.
Oh wait!!! Theres still the JB weld trick! heh.
Various Grinders
Victor Journeyman torch
200cf Acet. 250cf oxygen
Lincoln 175 plus/alpha2 gun
Lincoln v205t tig
Lincoln 350mp
Esab 650 plasma
When you can get up in the morning, Its a good day.
Live each day like its your last.
Old 01-05-2007, 10:32 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: 2024 aluminun
DON'T DO IT!!!!
you don't wanna be "it"..
...zap!
I am not completely insane..
Some parts are missing
Old 01-05-2007, 11:05 PM
tresi's Avatar
tresi tresi is offline
Re: 2024 aluminun
I'm licensed aircraft mechanic with 15 years of government contract work under my belt. If this is going on an aircraft you know that welding this would be illegal and unsafe. If you're using this in a non aircraft application you still would be better off attaching this rivets, screws or bolts. Aircraft alloys can be amazingly strong but with an equally amazing intolerance unapproved methods.
