Leaf spring mounts on axle
I used my torch setup tonight to cut some leaf mounts off an axle. What is the best way to get the left over metal off the axle? Just use a grinder? I ground 1 off using my 4" grinder and its painstakingly slow. Anybody got any good suggestions?
Thanks! |
Re: Leaf spring mounts on axle
I always use the scarfing/gouging tip for those jobs. With practice you can remove almost all weld w/o undercutting what you're removing it from.
Mike
Ol' Stonebreaker "Experience is the name everyone gives to their mistakes" Miller 175 mig Miller thunderbolt ac/dc stick Victor O/A setup Makita chop saw |
try using a cuting disk on your grinder man and then keep grinding thats what i did took only an hour or so to do two axles..
Hey jeep07, That's only about 10" or so of weld right? Shouldn't be too painfully slow. Are you using a Powerful grinder and a good stone?
NEVER Let oil come in contact with oxygen. I will not start stupid threads. Don't forget the upcoming air bumper test!
Yes scarfing is a good way and is fairly easy just remember only get the metal you want to get rid of hot.
If you are going to weld the mounts back on in another position, I would go very slowly and keep the housing cool. Years ago,I took a 1951 Mercury Spicer rear axle to a welder to have the mounts cut off, moved inward 2" and then re-welded for use in a different car. He did a nice-looking job. The only problem was that the axles wouldn't go back in. The housing had warped about /14" on each side.
I took it to a specialty welding shop on L.A and had it heat-straightened in a gigantic lathe. It taught me a lesson. |
Yes I know what you mean. I have done plenty of them on jeeps and other 4x4s take your time with them. I usually leave them on if I'm doing a spring over. I have made my own spring purches six inch to help prevent some minor axle wrap, but thats another story.
I start out w/ the torch or plasma then thin cutting wheel and finally the grinding wheel. I can see how maybe using some sort of air die grinder or something of that nature would take awhile; however , keep in mind you need to be carefull w/ that axle housing not getting it too hot on the other hand they are pretty forgiving. I say take you time. Anyway good luck.
weld it like you own it
