Old 02-13-2012, 06:41 PM
jreynoldswelding's Avatar
jreynoldswelding jreynoldswelding is offline
Good Diesel Silicone Maker
What kind of silicone is good for a small diesel repair on a rubber gromet/aluminum filter housing? without tearing the entire fuel filter assembly apart this is my only way to fix a small seap on my skidsteer. What will diesel not eat up? Thanks
You have to learn the rules of the game. And then you have to play better than anyone else.
Albert Einstein
Old 02-13-2012, 07:40 PM
farmshop farmshop is offline
Re: Good Diesel Silicone Maker
I have used permatex form a gasket not the rtv type silicone with good results on diesel.
Millermatic 252
millermatic 175
miller 300 Thunderbolt
lincoln ranger 250
smith torches
lots of bfh's
Old 02-13-2012, 08:06 PM
The "black one" ? Thats what several people have told me to use...Hows it hold up to the diesel?
Albert Einstein
Old 02-13-2012, 08:26 PM
TozziWelding's Avatar
TozziWelding TozziWelding is offline
Form A Gasket #2 or PIG Putty http://www.newpig.com/us/facility-ma...t%2B&adpos=1t1
Old 02-13-2012, 08:40 PM
Originally Posted by TozziWelding View Post
Thanks for the info, I dont want it to cure rock hard though. I will one day fix it correctly.
Albert Einstein
Old 02-13-2012, 09:06 PM
Forms gasket #2 works well I have used it on fuel tank gaskets otherwise black rtv holds for a while
Millermatic 252
millermatic 175
lincoln ranger 250
smith torches
lots of bfh's
Old 02-13-2012, 09:33 PM
power's Avatar
power power is offline
Diesel Tech here. what I use when the need arises and ONLY in the proper amount...alittle goes along ways. it is called ..right stuff.. and can be purchased in either sensor safe or not either one work well with a diesel fuel and or oil system can be bought at most parts stores. Dale
Old 02-14-2012, 12:18 AM
Dualie Dualie is offline
I second the right stuff. I get mine from the local napa. A little goes a long way.
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon inverters, XMT's, 250 Ton pacific 12' press brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas.
Lincoln idealarc tig 330A with bernard cooler Sync350LX. Miller migs, marvel saws
Old 02-14-2012, 03:21 AM
76GMC1500 76GMC1500 is offline
No gasket maker I know of works on deteriorated rubber parts. You're just making a bigger mess to clean up later. Replace the grommet and save yourself some hassle.
Old 02-14-2012, 08:18 AM
rexcormack rexcormack is offline
I hate silicone sealer!! Especially when I have to work on something that someone else has "fixed" with it!
Old 02-16-2012, 07:13 PM
farmall farmall is offline
If anything will work, B2 aircraft fuel tank sealant is the stuff.
http://www.aircraftspruce.com/menus/...ksealants.html
Clean with solvent, blow dry, scuff sand to get some "tooth", clean again, apply sealant.
It's not bothered by diesel, and is wonderful stuff compared to which RTV is pretty weak.
Anyone who hasn't tried it should buy some to get familiar. Wear disposable gloves, and mix thoroughly. It's quite sticky.
It's been used throughout aviation for decades, and seals "wet wing" fuel systems, canopies, panels. with release is used as panel faying sealant, and I've used it to seal a GM diesel timing chest while deployed to Incirlik when the Turkish motor pool mech went on strike. Works fine with gasoline too.
HTML code is On
