Old 01-27-2007, 05:53 PM
Mantis Mantis is offline
Repainting a Lincoln question
I recently picked up an old Lincoln AC-225-S that I'm in the process of reconditioning. The sheet metal had a lot of surface rust that I'm cleaning off. I'm going to repaint both the inside and outside of the unit. Do I need to use a special type of paint or primer? Does anyone know what manufacturer's color would come close to matching the original?
Old 01-27-2007, 08:30 PM
Doolittle Doolittle is offline
Re: Repainting a Lincoln question
Just use a good epoxy enamel or acrylic enamel. Make sure you get a good tooth on the bare steel (something for the primer to stick to).
Various Grinders
Victor Journeyman torch
200cf Acet. 250cf oxygen
Lincoln 175 plus/alpha2 gun
Lincoln v205t tig
Lincoln 350mp
Esab 650 plasma
When you can get up in the morning, Its a good day.
Live each day like its your last.
HTML code is On
