Old 03-28-2004, 08:43 PM
Jim314
Guest
Posts: n/a
Scrolling Along
After a trip to the metal purveyor, mowing the lawn, and a short list of honey do's, I finally got a chance to get to the shop. She wants a new queen size bed for the master bedroom, so I get to weld some more. Spent most of Sunday bending and screwing with the scrolls on the headboard. The footboard will be a copy of the headboard, just shorter.
Old 03-28-2004, 08:45 PM
Jim314
Guest
Posts: n/a
Old 03-28-2004, 08:46 PM
Jim314
Guest
Posts: n/a
Old 03-28-2004, 09:07 PM
dulknife
Guest
Posts: n/a
bed
jim i think that is very neat. do you have a patent on it or can i copy it. what did you fill the joints with. ken
Old 03-28-2004, 09:28 PM
arcdawg arcdawg is offline
Senior Member
REAL NICE MAN !!!!!!
Old 03-28-2004, 09:30 PM
Jim314
Guest
Posts: n/a
No dulknife, please copy it and post some pics when your done. The only joint that had to be filled was where the heart met the other scrolls. I had some small cutoffs that I put in the viod and just welded over them.
Old 03-28-2004, 09:51 PM
Sticky Sticky is offline
Jim,
You do very nice work.
Old 03-28-2004, 10:17 PM
dulknife
Guest
Posts: n/a
scroller
jim
one mose question. did you use the the template kit or just do it as you went thanks
ken
Old 03-28-2004, 10:45 PM
Jim314
Guest
Posts: n/a
I just did it as I went. The only feature I knew (or she knew) I wanted was the heart in the center. I just kinda built off of it once it was done. It's actually quite a bit different than what I had pictured in my mind before starting, but that's what I like about scrolls. You make 'em and stick 'em where you think they will look best to keep the design symetrical and flowing (Franz, I think I may be in need of a Retrosexual lesson here )
And dulknife, if you want any measurements, I'll be glad to post them.
Old 03-28-2004, 11:18 PM
Franz Franz is offline
Jim, all I'm gopnna say here is check the finish for handcuff scratch resistance before you paint or powder coat. Chips are just gonna look bad after all that fancy work.
Old 03-28-2004, 11:35 PM
Jim314
Guest
Posts: n/a
Handcuffs? In a bedroom? Is this one of those Retrosexual things?
Old 03-31-2004, 12:28 AM
YJMike YJMike is offline
No chips if you use the fuzzy handcuffs!!!
Mike
93 YJ
www.moabjeeper.com
Old 03-31-2004, 12:46 AM
mariner41 mariner41 is offline
Jim , Nice work on the head board. I was noticing an open book with scroll patterns on the page,that caught my eye, just behind the head board on the bench, in the pictures you posted. I was wondering if you can post the info on it, if it's a companys catalog, or a book publication with the authors name. Any info is appreciated, thanks.
mariner41
Old 03-31-2004, 08:25 AM
Jim314
Guest
Posts: n/a
Thanks Mariner. It's a King Architectural Metals catalog. It has a lot of scroll work pictured. Great for an ideas book. I had orginally planned on doing a scroll piece very similar to one I had bought from King Metals for my first bed. But it ended up being completely different from what I had originally planned. You can order a free catalog from them.
http://www.kingmetals.com/index.html
Old 03-31-2004, 11:42 AM
john pen
Guest
Posts: n/a
Jim, Just got the hf scroller/benthtop bender. Made a nice lamp so far, and looking to do a headboard like yours. My question is what did you use to get the arch comming from the heart between the scrolls towards the outside on the bottom half?
By the way, nice job
Old 03-31-2004, 07:20 PM
Jim314
Guest
Posts: n/a
Thanks John ! I got the arch by first making the scroll and then putting it in the ring roller I built. I ran it back and forth tighting the roller with each pass until I got the curve I needed.
You'll enjoy the bender and scroller. It's a little bit of money well spent.
Old 04-01-2004, 10:24 AM
rusted rusted is offline
That's very nice. Something like that will be in my future if I can manage that kind of craftsmanship.
Old 04-01-2004, 01:09 PM
jniolon jniolon is offline
Jim
really nice work... especially like how you blended in at the bottom of the heart... nothing like a welder and a flap disk, eh ??
oh and BTW don't use handcuffs... old silk neckties are better and leave no marks on tie point or tieie
john
Old 04-01-2004, 01:24 PM
Jim314
Guest
Posts: n/a
Thanks guys, and thanks for the tip john. I'd hate to mar a nice finish
Old 04-01-2004, 04:05 PM
sb62 sb62 is offline
Very nice! Showed my wife and she really likes it.
Could you post a pic or two of your homemade roll bender? I am working on mine right now and would be interested in what approach you took building yours.
Thanks
Steve
Old 04-01-2004, 06:43 PM
Jim314
Guest
Posts: n/a
Steve, here's a link:
http://www.weldingweb.com/showthread...ghlight=roller
Old 04-03-2004, 06:45 PM
hoagy_econo hoagy_econo is offline
Ring roller question
Jim,
What determines the angle that you mounted the drive roller, with respect to the two bottom fixed rollers. It does not appear to be 90 degrees, but a little off the perpendicular. What is the reason that this needs to be at that angle, and NOT at 90 degrees?
Sorry for the questions, but I'm just trying to understand the design.
Great craftsmanship, Jim !!
Jim Martin
Old 04-03-2004, 08:01 PM
Jim314
Guest
Posts: n/a
I actually don't remember why I did that. It was a trial and error project, so it was probably just a screw up. If I did it for a reason, I don't remember it now and there's really no reason to do it that way. Perpendicular would be fine. The main thing to consider is to be able to get the drive roller high enough when loose to get your ring, or curve, out after you finished. Mine won't raise high enough on small rings, so I have to unbolt the arms of the drive roller to get them out. But they're just finger tight, so it's no big deal.
Old 04-03-2004, 08:09 PM
Jim314
Guest
Posts: n/a
Damn, I just remembered why I had to do that. It wasn't a screw up, it was because of a screw up. I had to have it at that angle because the arms of the drive roller would hit the C channel that held the bottom roller if it wasn't at that angle. I knew I had probably screwed up somewhere, just couldn't remember where
Old 04-09-2004, 08:40 AM
7018 7018 is offline
Moved On
nice looking bed,good job there! im getting my bender with scroll atachment this sunday! Had it on my fathersday list of wants,but this way im sure to get it!!
