need help
I have a generater that has a 220 30 amp out put, my question is can I run a stick welder like this one on it? Lincoln Electric
AC225S Welder Model K1170 any other options? |
Re: need help
It comes with a 6-50 plug so it might be too much for the generator. You can always try using it on a low setting. I would imagine on the higher setting it may set off or pop the breaker or fuse on the generator. I'm sure others will chime in.
John - fabricator extraordinaire, car nut! - bleeding Miller blue! ![]() http://www.weldfabzone.com
Re: need help
I don't think you will get much out of the welder before you start popping breakers or fuses.
Dennis Thermal Arc 185-TSW Millermatic Challenger 172 VictorO/A Atlas Craftsman 12 by 24 Lathe Esab PCM-875 Wholesalem Tool Mill-Drill |
Re: need help
If the generator really puts out 30 amps of 240 volt ac you might get be able to get 120 amps or so before popping the breaker.
Re: need help
