Old 02-04-2007, 05:09 PM
spiral-cut-bevel's Avatar
spiral-cut-bevel spiral-cut-bevel is offline
PT 185: water cooled questions ?
Hi-
I was given a PT- 185 as a gift this past holiday. I have a few questions about changing my machine from an air-cooled torch setup to a water unit
I plan on upgrading to a water torch and closed loop cooler system. Can anyone recommend what brand water torch I should purchase. Should I go with the Lincoln water torch package or something like a Weldcraft ? Lastly, does anyone have any advice about building a closed loop water cooler? How many GPM should the system pump flow? Should the system operate on a thermostat? How much cooling capacity should the system have? Can glycol be run in the cooling system (my shop isn’t always heated)?
Any words of advice would be much appreciated!
Thanks-
Graham
HTML code is On
