Old 03-06-2007, 12:57 AM
ChenS ChenS is offline
Aluminium cleaning fluid
Does anyone use one of these pink fluids(probably some sort of acid mixtures) to clean the surface of aluminium plates?
Any recommendation for a certain brand?
10X
C.
Idealarc 300\300 TIG AC\DC
Old 03-06-2007, 01:11 AM
Re: Aluminium cleaning fluid
Acetone...that's it.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 03-07-2007, 02:45 AM
weldingman24 weldingman24 is offline
we use protex alclean at work if the material is really dirty. it works well on castings but it strips (eats?) the surface of the aluminum off. I know some tow truck drivers that use it to clean their aluminum flatbeds just don't ever get it on
your hands or clothes
Old 03-07-2007, 06:08 AM
David R's Avatar
David R David R is offline
I use the pink stuff in a bottle. Well, I have a bottle of it, but always end up using a wire wheel, or a SS wire brush. I have had the bottle for 15 years if that tells ya anything.
Its at work, I will get the name today.
David
Real world weldin.
Old 03-07-2007, 09:25 AM
Thanks David,
I've seen it stripping alluminium coatings and dirty manifolds casting in seconds without the need to scrub or brush , just "paint" with it on the work metal with regular paint or tooth brush and the piece comes out shiny,I guess it may be usefull for Ti oxides layers as a reducing agent but I may be wrong here.
P.S
I have one fluid for SS , its some sort of a strong acid , same procedure , wait 30min and then wipe with water and soap, it removes the greyish-blue-dark leftovers that present over and around the weld , very nice for headers jobs...
Old 03-07-2007, 12:36 PM
CarmenElectrode's Avatar
CarmenElectrode CarmenElectrode is offline
acetone is nasty smelly stuff!! we carry EZ Wipes... individual wipes for cleaning, in a plastic canister. They're pretty popular, and one side is sort of rough for "scrubbing"
Carmen Electrode
www.CarmenElectrode.com
and the boss blogs at www.JoeWelder.com
all powered by www.Arc-Zone.com
Old 03-08-2007, 05:18 AM
I have some too , they sometimes leave little fibers on sharp metal edges though.
