Old 03-06-2007, 01:50 PM
Kraftymate's Avatar
Kraftymate Kraftymate is offline
Welder Powered by Inverter
Does anyone know what size inverter (like one you plug into a auto lighter) can be used for powering a small 115v Wire Welder. Or is this possible?
kraftymate
Old 03-06-2007, 02:00 PM
pulser's Avatar
pulser pulser is offline
Re: Welder Powered by Inverter
I guess you need to look up the input power requirements for the 115v welder. How much power (A x V = Watts) does it draw at the output current level you will be welding at?
Old 03-06-2007, 04:23 PM
enlpck enlpck is offline
kraftymate
That plugs into the lighter? There IS no size that will run a welding machine. You will get a maxinum of about 250W through the lighter socket (20A at 13.8V), and that is pushing it. The smallest of machine, turned down low is going to run 1KVA or more. (figuring 40A at 16V, with 66% efficiency for the whole system, which is optimistic) A 2.5KVA inverter right to the battery might be sufficient, but is going to be pretty rough on the inverter.
Your best solution if you need to do this is likely something like a ready-welder, designed for the application.
Old 03-07-2007, 09:47 AM
Patriot Performance's Avatar
Patriot Performance Patriot Performance is offline
Not going to happen. Even a 3000 watt inverter wouldn't be sufficient. Those are very expensive to say the least.
I have a 750 watt peak inverter in my Ram and it hardly runs a corded drill.
Patriot Performance Auto
Lincoln Power Mig 255C
Lincoln AC-225 Stick
Victor Journeyman O/A
Quincy QT-5 Compressor
Old 03-07-2007, 09:32 PM
littlefuzz's Avatar
It would take a huge inverter. you'd be better off with a generator and i'd be cheaper. definitaly won't do it through the cig lighter anyway.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
[IMG] code is Off
