sheet metal brake
I needed to bend some sheet metal but I did not have a brake and could not justify spending $ 250.00 for a cheep brake so I decide to make one myself. I still have to get a two small springs to lift the angle iron that acts as the clamp to hold it up .The thickest material I have bent is 1/8"thick 4" wide Aluminum diamond plate. Here are a few pic's
Re: sheet metal brake
That's the best simple design I've seen for a small bending brake. You have all the correct geometry for it to work properly and clearances needed with minimal work to build.
Millermatic 252 XMT 304 Dynasty 200DX Hypertherm PowerMax 1250 Miller The Legend AEAD200LE Suitcase 12RC Suitcase 8VS Optima Pulser XR feeder and XR Edge gun and more at http://members.dslextreme.com/users/waynecook/index.htm |
I like your design. Good job. Any pictures for your bends?
X2 here!
Cheers,
Miller Diversion 165 120 amp Buzz Box Victor Oxy/Ace Oxy/LPG Smith "Little" Oxy/LPG Hypertherm Powermax 30 Lot's of Misc. tools n' crap.... |
nicely done - but It looks as if its about to fall off of that barrel
Thermal Arc Fabricator 210 1970 Lincoln Redface Miller 150 STL Still need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a.... My other addictive hobby; http://frozenpixels.smugmug.com/ |
the only bends I have pictures of at this time are a few bends on my mini truck frame section that had to be replaced 3/32 thick steel by about 12" long. I know the welds need more work but I was running out to time I had to get the truck out of the shop I have to go back over them soon . but thre are the pics"
Nice job.
What's the maximum width you can bend?
Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
the max width is 31 "
