Old 04-08-2004, 01:35 PM
madmaxxx madmaxxx is offline
ESAB Multimaster 260 Pulse welder?
I'm looking into the new ESAB Multimaster 260 Pulse welder.
It has Tig, Mig and Stick. In my opinion its fairly reasonable.
-has anyone had any experience with this welder?
-does anyone know of a good source to buy this from?
-if not what's a good multi-process welder in the same price range $2100-2800.
Thanks
Old 04-08-2004, 02:09 PM
Scott V Scott V is offline
As a pretty big esab fan I would just try to find a deal on a powermig 300.The esab 250 plus is a better mig welder then the 260.When you add up all the gagets to turn it into a decent tig welder or even a good pulse welder you will be over what a powermig 300 will cost.The only way the esab makes sense is if you want a mig stick unit.Even then the powermig has a more refined stick welding settings.Check on some of the option prices before you decide on that machine.I think the pulse and inductance will be way over a $1,000.00 extra.Then you will need a tig control add on for lift-arc.Just trying to clue you in on what looks like a good deal might not be.Most esab reps that I know still think the 250 plus is the better short-arc mig.
Old 04-12-2004, 12:48 AM
arcdawg arcdawg is offline
Senior Member
i would stay away from esab, go red or blue.......... the pm.300 is great too!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
