Hi. I'm building a tank, and I'm concerned about penetration in a few areas of my joints. I'm TIG welding 1/8" 5052 H32 aluminum with 3/32 5356, and as you can see from the photo, I have no back side penetration in some areas. The weld on the front side looks good, my question is, can I just run another bead on the inside of the corner joint? I ask because I don't know if there's some metallurgical reason why I shouldn't (e.g. it will make the weld more brittle or something). What about the area where it looks like I did get penetration, can I run another bead on the inside of that area, or will problems arise from re-melting that area?
