Sand blasters
12K views 21 replies 10 participants last post by  dellwas
I am looking for some tool recommendations... specifically, i plan to start restoring my 96 bronco and i am looking for different tools to clean paint/rust off the truck. I've got an angle grinder i can put a wire wheel on, but i was also thinking of getting some kind of sand blaster. Does anyone have recommendations around them, good or bad? i would be using it outside since i dont have a shop.
#2 ·
I bought the 110lb. Harbor freight sandblaster.
I can get it to work by Not following the directions
I would not recommend this particular sandblaster
#5 ·
This is what I would recommend if you have a spot outside like a driveway or cement slab that is away from other things. I am looking for a 4gpm 3200psi pressure washer right now. I am going to pour a cement slab behind my garage well away from everything to set things on for blasting. The reason for the slab is for easier clean up of material after the water has dried up. I do not want it to keep building up in one spot. If you are only going to do a few items the slab would not be needed. you could probably get by with laying a tarp down for the short term. This type of blasting is much faster than air sand blasting and easier to clean up after if you plan and prepare for it.
#4 ·
I have a 100# pressure blaster from Eastwood. Its probably 20 years old now, and has seen a fair bit of use.
Trick with sandblasing on a complete car is masking it to keep sand out of places you don't want it. I can be done, but is difficult and time consuming. Once you figure that out, you really need to practice a lot before having at your sheet metal. Its very easy to overdo things and warp panels.
Blasting disassembled parts is easier, and the heavier the metal the better. Frames, suspension components, etc can take coarser sand and more pressure. You need to throttle way back for sheetmetal.
All of this assumes that you have a big air compressor. I have a 5hp cambell housefield with a 60 gallon tank. Its really not big enough to run things, but I have gottten away with it over the years by using smaller tips. It still runs continiously and will likely blow up one day. Give me an excuse for a better unit.
If you are only planning to do one vehicle, I doubt the investment in equipment is worth it. Better to find an expert and pay them their money.
#17 ·
Thanks for the info. This is one I want to do for the sake of me doing it, nothing more. While I am stuck behind a desk every day, and the fact I grew up building houses, I long to dive into a project with my hands that far exceeds my knowledge and skills.
The sand blaster is probably out of my budget, and the harbor freight + a storage tank + my 60gal ch compressor might pull it off.
I probably won't go the route of the wet as I need to do the inside too, and won't completely disassemble the parts.
Sent from my XT1254 using Tapatalk
#6 ·
Thanks everyone. looking into the ones that attach to the pressure washer now. that would save me a bit given i have one.
Not sure how this restore project is going to go as it's my first attempt, and i'm learning as i go :)
#7 ·
From someone else who has leapt many times before looking...
Wishing you lots of good luck and learning.
It takes a whole lot of CFM (50+) to run a good sandblaster.
Also note that silica sand is not used much any more. Ground coal ash (Black Beauty brand) for powering through most anything. Down to baking soda for getting lacquer paint off irreplaceable car parts.
#14 ·
LOL. i can just see some of the comments... why did you need to build a sand blaster... umm... to sand blast some metal i used to make a sand blaster :). My skills are not at the point where i would build something that could hold that pressure, but awesome video
#15 ·
Cool! Only thing i am not sure about is using a wet blast inside the truck. looks cool though, might be really great for doing the wrot iron hand rails around my house
#16 ·
IMO you can't beat sandblasting for weld prep in certain situations. Inside corners get cleaned out with sand like no other process and fast. With sheetmetal it will take all the paint, rust, scale, dirt, slag, etc. but leave all of the solid metal, very important with thinner sections where you will need all the thickness you can save. Doesn't load up with paint like a grinding disc. The profile (surface texture) will be consistent, a plus for high end paint prep. The only time it didn't do all I needed to do was a piece I intended to MIG was covered in everything but poo, uncovered a brazed section that had to be ground out.
I agree with with almost everything Zimm had to offer.
I don't have favorable results on rust with wire wheels, they tend to leave some of it and just polish it.
I have a little touchup rig (80# pot with 5HP/60 gallon compressor/tank) for small welds, the big pot and 185 cfm for large projects and paint prep on trailers, dump bodies, etc.
Cons: As others have said, you need air- 5 HP is minimum, 7+ preferred. Loud and dusty, sure way to piss off the neighbors if they are close. Larger than the 100# pots and 12-15 CFM, the cost jumps in a big way.
