Looking to weld a washer and nut to the inside of the tans oil pan then another washer on the outside so the bolt will have a nice flat surface to seat against on the 95 EB Bronco. Has any one done this using mig .023?
What's your thoughts on doing this so it don't burn through yet won't leak. I was thinking of just spot welding every thing little tacks at a time until it's fully welded all the way around inside and out then go over it afterwards with a solid bead to add strength like a second pass.
